Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Where can I purchase a power cord for this product?
  • 973 Answers
Http://usa.kyoceramita.com/americas/jsp/Kyocera/downloadsupport.jsp
You can click on the link above for a list of Contact numbers and Dealer locations to purchase the part you are looking for.
Posted on Jun 04, 2010
Hi . I'm moving from USA to Europe. Can I use my HP 2159m monitor with 220 V instead of 110 ?
Yes. But you'll need a different power cord:
The monitor power supply is provided with Automatic Line Switching (ALS).
This feature allows the monitor to operate on input voltages between 100-240Vv, 50/60 Hz, 1.5A.
The power cord set (flexible cord or wall plug) received with the monitor meets the requirements for use in the country/region where you purchased the equipment.
If you need to obtain a power cord for a different country/region, you should purchase a power cord that is approved for use in that country/region.
The power cord must be rated for the product and for the voltage and current marked on the product's electrical ratings label.
The voltage and current rating of the cord should be greater than the voltage and current rating marked on the product.
If you have questions about the type of power cord to use, contact your HP-authorized service provider.
A power cord should be routed so that it is not likely to be walked on or pinched by items placed upon it or against it.
Particular attention should be paid to the plug, electrical outlet, and the point where the cord exits from the product.
Jun 03, 2018 | HP Computers & Internet
Inspiron 620 desktop will not power on. Change out of power cord was done whilst under warranty (7/12-7/13). Purchased 7/13. Warranty is up. Have not tried to power on since August--it powered up then....
A computer will not power on in certain conditions follows
  • RAM Failure. i.e, RAM is not properly inserted into the port, or any dust particle presence in its port, I am sorry to say The RAM is in DEAD condition
  • Mother Board Failure. Any overflow of power enters into the motherboard. motherboard will burnout (due to lightning, Voltage level increasing etc)
  • Power Failure
  1. When the power cord is properly functioned or loose connection
  2. SMPS is under malfunctioning (SMPS Burn out)
  3. Power cords from smps to mother board,HDD,CD drive fail
  4. Short circuits etc
Check it out...
Jan 22, 2014 | Dell Inspiron 620 ST Desktop Computer...
Customer has lost his power supply cord. where can he purchase another cord. power cord is three prongs.
  • Hi, I can help.
  • For the Radio Shack TRC-447 this is just a standard 3 PIN DC cord. Many CB's use the same cord and they are interchangeable. Some Cobra, Uniden, Radio Shack use the same cord. Texxcomm is a great place to get parts from.
  • If you have any coimmments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 07, 2011 | Radio Shack TRC-447 CB Radio
I need a power cord for an HP Scanjet 5400c
If it's just the power cord you need, monoprice.com has excellent prices. Here's the cord listing:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10228&cs_id=1022806&p_id=1307&seq=1&format=2
If you actually need the entire power adapter, that's a bit more complicated. There are a lot of online vendors, but I'd need to know your location and "risk tolerance" to give you the best purchasing options.
Oct 25, 2010 | HP Scanjet 5400c Flatbed Scanner
HB Officejet 6500 scan button not working
Follow these steps to perform a partial reset of your product.
  1. Unplug the power cord from the product, and wait 20 seconds.
  2. Press and hold # and 3 while plugging in the power cord to the product.
  3. Release the buttons after the product starts up. The product will now be reset to factory defaults.
Aug 13, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Need power cord for window Whirlpool a/c
Their information is absolutely not correct. You can purchase replacement power cords for any product.
If you prefer, I can provide you with the correct replacement cords; I simply need the brand and model number of the AC units
May 01, 2009 | Heating & Cooling
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
I need a power cord and remote for tv
hi,
no problem purchase remote control from blow link --
http://www.google.com/products?hl=en&client=opera&rls=en&hs=VYV&q=purchase+konka+tv+remote&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
and purchase power cord from ---
http://www.google.com/products?hl=en&client=opera&rls=en&resnum=0&q=purchase+konka+tv+power+cord&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
please give me FixYa if you find the solution
Thanks for using FixYa
Jan 05, 2009 | Konka Televison & Video
I need an electrical cord for a 3930 deskjet printer
Power cord Part # is 8120-6260
http://www.google.com/products?hl=en&q=8120-6260&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Adapter part # 0957-2119:
http://www.google.com/products?q=0957-2119&btnG=Search+Products&hl=en&show=dd
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 05, 2008 | HP DeskJet 3930 InkJet Printer
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
29 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
