I keep geting a scsi 2 error and the drive reads on my akai dps 12 {record not ready) and unable to format.
    Genius:
  • 1,665 Answers
  • 19,396 Answers
Either the cable is defective, or the scsi device, or you just need reinstalling scasi driver we need more details on your hardware
Posted on Apr 09, 2008
  • Ginko
    Ginko Apr 09, 2008
    If you get the message and you do not use a scsi Hard disk or cdrw then you must set up the akai for using the correct storage device (eg. zip drive or ata HDD)
    If you have a scsi cdrw, then the cd drivr is probably faulty, just replace the cd with one in compatibility list.
    If you are using your AKAI with a scsi hard disk then it lost connection to the hard drive. Could be a misplaced cable , or the hard drive that is gone. You need to pull out the hard drive and test it with a computer and a scsi card, eventually recovering the data inside.
    If you have to replace HDD you need to get one within the compatibility list here.
    If you cannot do it yourself, any skilled computer repairman should be able to do do the job with the right info (you can pass a printout of this solution) , in this case find a service in your area, it should not be an expensive repair.
    Regards
Which particular SCSI to USB cable do I need to connect to my laptop?
Consider looking at newegg or Amazon. They will usually have verity of cable sizes and model to deliver the needed job.
best of luck!!
Sep 13, 2014 | Akai Professional Dps 12 Track Recorder...
Why is my AKAI DPS 12i recorder is making loud loading noises as i rec or play back the songs? there is about 12 songs on there could this have anything to do with it?
It has nothing to do about the amount of songs present at this device. It has to do about it\'s hardware. I\'m not sure if there\'s a fan inside to cool a processor or other parts (check at the back of this device where all connectors are located). If there\'s dust in the fan-section, the fan has to suck more air, being able to cool the interior devices.
Oct 14, 2013 | Akai Professional Dps 12 Track Recorder...
Can't connect my CDRW to the DPS12
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Sep 13, 2012 | Akai Professional Dps 12 Track Recorder...
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Dvd rOM BURNER HAS ERRORS
Try a new DVD ROM. They are very inexpensive.
Mar 23, 2017 | Computers & Internet
Not reading my floppy disk( MPC 2000xl by akai)
Have you tried formatting the disc using your MPC 200XL?
Mar 20, 2009 | Music
Rathwynn
Hey there
The most common cause is that setup does not have the driver for a SCSI device or is detecting storage devices in the wrong order, such as that CD-ROM drive first.
Press F6 when setup first starts and provide a driver for the mass storage device that will hold the operating system files.
Check to make sure all adapters and controllers are working properly.
Check power to all devices. Reseat adapters and controllers.
For SCSI devices ensure:
1. The SCSI cabling is properly installed.
2. SCSI devices are terminated.
3. SCSI devices are correctly addressed. And
4. The BIOS correctly recognizes all SCSI adapters.
Also, be sure the SCSI boot drive is addressed as 0.
Check the manufacturer's recommedation for configuring SCSI adapter and Hard Disk Drives. Try replacing the adapter before replcing the drive(s).
For EIDE Drives:
1. Check the controller.
2. Ensure file I/O and disk access are set to standard. And
3. Ensure that the system drive is the first device recognized by the controller.
For IDE and ESDI drives:
1.Check the cabliing and controller.
2. Check the Drive setup in the BIOS for master/slave relationships. And
3. Ensure the drive is properly recognized in the BIOS.
Gimme acknowledge by rating me.
thanx
Romy
Aug 05, 2008 | Intel Motherboard
DISK ERROR WHEN I TRY TO USE MP3
I had the same issue and just connected the device to my computer USB connection and performed a quick format on the drive and it now works. You will be warned that reformatting the drive will erase all the data, which will happen. But you can simply reload your music and be back in business... Rod
Jan 17, 2008 | Delstar DS 31024 MP3 Player
Crw8424s scsi
the drive is ready to give up, when it cant read dvds or cd's and unable to eject because it cannot read tracks and commands it's time to buy a new one, they are very cheap and easy to fit yourself.
Sep 26, 2007 | Yamaha CRW 8424 Burner
81 people viewed this question
 Grubhead
Grubhead
