Question about Frigidaire FGB24S5A Gas Single Oven
Frigidaire FGF326ASA gas oven
The top gas grills work but the oven will not turn on. There is no smell of gas when the oven or Broiler is turned on and light on the top of the oven is on. When inspecting the ignitor it does not glow. I would think at least there would be a smell of gas. Does this seam like i need to replace the ignotor or is this a bigger electrical problem.
  • Brownie00 May 30, 2008
    I have the same problem. It started that it would take forever to light and now It won't light at all. After a while it makes the whole house smell like gas. It seems that the valve is opening but not enough to light. Earlier my wife got it to light but the flame was very weak. The igniter works and glows pretty darn hot. Could this be a voltage problem caused by a bad igniter. Or is the saftey vlave bad or possibly plugged? can the saftey valve even be cleaned, or should it just be replaced. I would really appreciate any help.
    Thanx
    Ryan
After pricing the 2 ignitors and a dual saftey valve (could be all) the best price for all is around $225.or more. Doing the labor myself. Im going to just buy another stove. And I think Ill get one with a pilot light(cheaper to fix) and no self cleaning(dont use much anyway if you are carefull with spills. Price? about $270-370. free del.. and haul off. ibojuan40
Posted on Dec 15, 2008
  • 135 Answers
If both the broiler ignitor and the bake ignitor are not working it is unlikely they are both bad. You may have another problem. Need to check voltage to the ignitors to be sure.
Posted on Apr 09, 2008
Frigidaire gas oven not heating. The broiler and burners work but the lower burner will not ignite. I replaced the igniter however that did not fix the problem. In fact, the new igniter does not glow. I...
Check for volts to the new ignitor. The ignitor draws current which opens the gas valve. If it is not glowing it is not drawing power. Test the ignitor,disconnected, with an ohm meter, it should be under 200 ohms.
Dec 28, 2013 | Ovens
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
Frigidaire gas oven, broiler works, oven does not
Sounds like you need a professional to diagnose the regulator and element valve to the bake element only.
Jul 21, 2012 | Ovens
Stove top working, oven is not
you need to check the heating elements and make sure you have continuity if you do then replace the control board
Jan 29, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven will not work - Hi/Lo broiler works fine
you have a bad bake ignitor. it is mounted to the long tube in the very back wall of the tube. usually held on by 2 1/4 inch bolts. usually if you replace the ignitor you have to cut the old one off and hard wire the new one in depending on what the new connection on you ignitor look like.
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not lite
Unplug the unit, change the igniter maybe it does not draw enough ampage.
or check the gas control knob if somebody mistakenly turned it to off position. the ON position should be inline with the gas pipe.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
WILL NOT CONTROL TEMPERATURE
there is some adjustment in the switch to control it but according to ur problem the switch is weak though if u adjust the switch it will work properly only for few days or few months instead u can change a new switch to fix the problem permanently
Jun 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
Whirlpool oven model sf315peew Super cap 465
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
Jan 30, 2008 | Ovens
Frigidaire FGB24S5A Gas Single Oven Logo
809 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
