Toshiba How will I know if the fuse is good or bad? Is it like a house fuse, i'll see something broke inside, or what? The TV is only 3 years old, at best. Is this typical with TV's?
  • 170 Answers
The fuse is a gma fuse, you can use an ohm meter and if its good the fuse will read shorted. or goto zero's.
Posted on Apr 09, 2008
Location of fuses for cabrio dryer # wed6200swl
pull out the dryer,remove the vent line and remove the back wall,you'll see the metal duct that the lint filter slides down into,look to the bottom right of the duct,you'll see a white piece with two wires on it,this is the thermal fuse part number 3392519,fuses are usually on the blower wheel housing and on the heater housing,if the lint filter is on top then the fuses are in the back of dryer,if the lint filter is inside then the fuses are up front.if the fuse is bad you have to clean out the dryer and blow out the vent line,remove the duct that the lint filter slides into,your filter is on top so remove the two screws that are in front of the lint filter onthe top panel,then if the vent line is long you can blow it out with a leaf blower,first go outside and make sure there isn't any covers or anything blocking the vent,if there is a cover remove it,the lint will keep getting stuck in it and you'll have check the thermal fuse and if that's good check the thermostats and high limit on the heater box,also make sure you have 240 volts going to the dryer,check the door switch,also make sure the belt isn't broke,there's a switch that kills the power if the belt is broke.hope this helps if not you could have a computer board issue
Sep 07, 2012 | Whirlpool WED6200S Electric Dryer
Does TV have a fuse or reset button? Where are they located?
Yes, all TVs have a fuse. You'll usually find it in a spring-clip holder on the circuit board inside the cabinet. Look for it in the area where the power cord connects to the board. Most TV sets use a small cartridge fuse, but some sets use a different type.
If you're asking this because your TV has gone dead, just be aware that if the fuse is bad it's normally because something else in the set failed and caused the fuse to blow. Fuses very seldom just go bad on their own. If you change the fuse, don't be surprised if it goes bad again.
And while this should go without saying, I'll say it anyway: be sure to unplug the TV from the AC outlet before taking the back off. You can get a nasty shock if you forget this step.
May 22, 2011 | Daewoo DTQ-27S5FC 27" TV
Wont turn on. is there a fuse or something inside
The unit has fuses but you will probably not find any bad ones. I would check the power supply for problems. If you unhook all but the control board it should produce all it's voltages which are usually marked by the connectors. If voltages are good the problem is in one of the boards which are unhooked. It would need replaced. If the voltages are not there the power supply board needs replaced. Let me know how you make out.
Jan 31, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have a Toshiba Projection Television 61A61 that I cannot change the contrast once on sports. When I do change it, it automatically goes to preference and I also have these almost double type on the...
Thanks for using FixYa. The TV will automatically turn itself off after approximately 15minutes if it is tuned to a vacant channel or a station that completes its broadcast for the day. This feature does not work in VIDEO mode. If the power is cut off while you are viewing the TV, the last mode memory feature will turn the TV on automatically when the power is re supplied. If the power is going to be off for a long time or you are going to be away from your TV, unplug the power cord to prevent the TV from turning on in your absence. You’ll also need to check the swollen/bulged capacitors on the power supply board inside the TV. The TV itself turned it off in the case of any bad capacitors or overheating with the help of built-in sensors. You’ll need to replace the swollen/bulged capacitors. Please also check the power from and to the TV.
Please do rate the solution and revert for further assistance.
Oct 11, 2009 | Toshiba Televison & Video
D52W20 52 in. won't come on. Green light only blicks but no TV. Something broke inside I suspect. Fuse is good.
Ck capacitors cp150 2200uf 14v if it is swollen or puffed up on top it is Bad replace cp114,cp120 as well 220uf 35v. resolder all pinns on FBT flyback transfomer this caps are on the deflection board First bottom board to the left.
Sep 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Want to check fuse on 46h83 toshiba
only fuse I know is near back of tv inside power section right next to the power cord input ... my first thought tho is damaged capacitors inside same area ... good luck getting it apart ... I took mine apart but difficult to figure how
Jun 10, 2009 | Toshiba 46H83 46" Rear Projection...
Broke the plate above the funnel -- Bunn NHBX
The plate inside is not repairable. If you will get the model and date code from the bottom of the brewer and contact customer service, the brewer can be replaced. If the brewer is 3 years old or less, it will be replaced at no cost. If the machine is over 3 years old, it will be replaced at a reduced price.
Jan 11, 2009 | Bunn NHB Coffee Maker
Hello fixedopsmike,
There is a fuse in the TV set, if you would like to check and see if it has blown, here is a way you can do it:
1) Unplug the TV's power cord from the wall
2) Take the back off of the TV by removing the screws and slowly removing the back panel.
3) Look for a component that looks like a glass tube with metallic caps on each of the ends, this will be the fuse.
4) Visually inspect the fuse to see if it shows signs of being open (Blown) These signs are burn marks inside of the glass tube, an open conductor (wire) inside of the glass tube, or no visible wire inside of the tube.
5) using a multimeter set to resistance (R x 1) test the fuse for continuity (remove and change the fuse if found to be defective)
6) If the fuse is not bad, reinstall the fuse if removed, put the rear cover back on.
Now at this point we have determined if the problem is a fuse being blown or not, if you replace the fuse and the TV works great the problem is solved, if you replace the fuse and it blows again, or if the fuse was ok to begin with, then you have a problem that will require some knowledge of electronics pass the basics to continue on. At this point I would suggest that you call a qualified TV repair technician to troubleshoot and repair the TV in question.
I hope this helps,
Thank you,
Nov 22, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba SD330E
take off the back of the tv and look for a glass fuse if the inside of the fuse looks broke replace it by going to radio shack if still no fix get a new tv sincerely john
Aug 01, 2008 | Toshiba SDV393 DVD Player/VCR
Glass or something behid the screen broke
Misha, I have bad news for you.
There is only one part behind that screen to break - a rather large mirror.
To verify:
Lay the TV down, face down, on a towel.
Remove the screw from the upper rar black plastic housing.
Lift straight off - you should see the mirror, or what is left of it, attached to the black plastic.
Sorry for your loss.
If you are interested in selling the ballast, let me know.
Jul 30, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
