Question about Philips 200P4 (Silver/White) 20.1 in. Flat Panel LCD Monitor
Flat panel computer monitor has bars and stripes all over it
I have a Princeton flat screen monitor with both DVI-D and VGA hookups. It works great when I hook it up to my laptop via a vga cable. However, when I use the same cable and hook it up to my desktop computer I get all sorts of weird bars and stripes on the monitor. (Note: The computer only has DVI port so I used a DVI to VGA adapter - this monitor has worked successfully in the past this way) Then I tried a DVI cable and hooked it up from the monitor to the desktop computer and got the same thing.
So I know that A) the monitor does work since it works with the laptop perfectly and B) The vga cable works since it also works hooking up the monitor to the laptop. and C) The problem is not the DVI to VGA adapter since I get the stripes whether I use a VGA cable with the adapter or the DVI cable directly
So now I'm wondering if something is wrong with the DVI card on the desktop? I am hoping I can try putting in a new DVI card (or vga card?) onto the desktop and get some more use out of it - even if it's just letting my kids play some games and simple web surfing.
Please let me know if anyone has a clue what to do. I am not technical at all but I wouldn't be afraid to try to fix it if it is cheap enough fix. I figure I have nothing to lose - am trying not to have to buy a new computer. Thanks for your help!
    Top Expert:
  • Philips Master
  • 26,203 Answers
Probably as cheap to replace a monitor, sorry to say.
Posted on Mar 01, 2017
3 Suggested Answers
  • 125 Answers
SOURCE: I have a Philips 47" flat screen it has HDMI
First of all you must check that your laptop supports a protocol called "DHCP" over DVI. Otherwise you are chasing your tail. This information will probably be in the manual or available online. DHCP is a special handshake protocol for HDMI and your television and computer will not talk to eachother without it. If you find it to be compatible you need to lock down which input on the TV it is. Plug something in via HDMI and verify you see it. Then unplug it and plug your computer into this port. You don't want to be flicking through inputs trying to find it. Also, hook up an external monitor to the laptop and figure what needs to be done to display on it. Then try the television. My guess, though, is that you won't find DHCP compatibility if it is an older laptop. My best advice is to buy a Playstation 3 and watch Netflix with that. Otherwise you'll need a different way of hooking up which might include buying an expensive converter box and/or watching poor quality video.
-Good luck
Posted on Apr 24, 2011
Terry Corrow
  • 10875 Answers
SOURCE: Philips 190G having issues using it only as speakers. Stand-alone Speakers mode
Your TVs sleep mode is activated. Disable it on your TVs menu under settings http://download.p4c.philips.com/files/1/190g6fb_00/190g6fb_00_dfu_aen.pdf also d/l new drivers for your monitor and install them.
Posted on Mar 09, 2015
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
Will my 64mb GF2 support dvi and / or hdmi connection (I want to get a flat panel monitor)
Not directly......but no worries!
All hope is not lost with just the VGA out on your card!
First, every flat panel monitor I have ever seen has a VGA input, so your GeForce2 card will still work!
VGA is still the top analog signal standard for computers. I am writing this with my on-board NVIDEA GeForce, connected to a Viewsonic VA2226w flat panel monitor using VGA and set at a resolution of 1680X1050!
Almost forgot..... just ignore the "TV Out" on your card.... this is old school and will give you nowhere near the quality you will get from VGA.... it was meant as a "crowd pleaser" to allow people to connect to their old school big screen TV sets.
Get the flat panel display... you will find out that it will work just fine with your VGA connection.
Feb 19, 2011 | Nvidia GeForce2 MX400 Graphic Card
Today, my monitor went to a multicolored candy-striped screen. I have to keep unplugging it (at the back of the monitor) until it works again. Every time I plug it back in, it's a different weird screen...
1) Replace the Monitor Cable, VGA is generally a Blue connection and DVI is a cream/white.
2) Make sure there aren't any bent pins in the end of the cables
3) Try the monitor on another working computer to verify it works or not
4) Replace the monitor.
If the monitor works on another computer then chances are that your computer has corrupted video drivers or a bad video card.
Dec 22, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
What type of flate screen monitor can we use with a e machine t3604. We have tried a MAG innobision and it does not work. Model
Any flat panel screen should work. if the screen has DVI input you'll need a DVI to VGA adapter you can get flat panel screens that have VGA connection or both.
Aug 06, 2010 | eMachines T3604 PC Desktop
Have old computer ,do not have directdvi-d connection on my computer, can I buy adapter to fit old monitor plug?????
Princeton Digital VL2018W has VGA and DVI input ports, why not use the VGA cable from your old PC to the VGA input of the Princeton Digital VL2018W?
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Aug 01, 2010 | Princeton Digital VL2018W Monitor
My monitor is blank it just keeps saying self check its a dell flat screen
If it shows "Self test feature check" the cable (VGA / DVi ) is unlplugged on the computer/ tower. Check the cables it may be loose. If not, try replacing the VGA/DVi cables. The LCD is good since it was able to display the self test feature check.
Hope this helps.
Mar 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Screen prob.
For flat panel systems there are 2 inputs. DVI using the white cable and VGA. by default flat panels are set to DVI input. hit the menu button on the screen and there should be an option there to change the input video. if this will not work it could be a problem on the video port on your acer computer or it could you might need a new VGA cable.
Oct 11, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
Philips 200P4 (Silver/White) 20.1 in. Flat Panel LCD Monitor Logo
176 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
