Question about Ingersoll Tools & Hardware - Others
Have an ingersoll model8049 electric impact wrench and I need brush holder/direction changer assembly! Where can such parts be located?
  • 718 Answers
SOURCE: electric impact wrench runs slow with no power
ALL Sears products have the replacement parts listed at;
http://www.searspartsdirect.com/partsdirect/index.action
Enter you model number and you will get a diagram and parts/price list.
The people at Sears should have known that. Sears also have free-standing hardware stores in many areas.
Posted on Apr 08, 2009
  • 3600 Answers
SOURCE: I am looking for a carbon brush housing
You can buy at Nappa auto parts stores. Please rate as this is a short answer and if you don't rate it it hurts me.
Posted on Aug 06, 2009
dontbother10
  • 2220 Answers
SOURCE: Where do I get parts for a Wen 6014 electric chain
Wagner purchased Wen long ago. Try these, if they can't help neither can we.
WagnerSprayTech
http://www.wagnerspraytech.com/portal/finding_a_product_manual_spray,98115,747.html
WenProducts.com
http://wenproducts.com/
Posted on Sep 18, 2009
SOURCE: Need exploded diagram of ingersoll rand Model 8049
Here you go... I needed the same...
http://www.powertoolrepairohio.com/pages.php?pageid=14&breakid=1118
Posted on May 22, 2010
SOURCE: i need spare parts for my saw and if possible a
mastercraft 10" compound saw model #55-6802-6-- need spare parts - How do i get them.
Need center bolt for blade
Posted on Dec 05, 2010
Ws550 eletric. i need the forward and reverse switch for my ingersoll electric wrench
Ask your IR dealer for this part > IR 201718 SWITCH, last price I saw was around $38.00
Sep 12, 2013 | Ingersoll Rand Ingersoll-Rand 1/2 in....
Diagram of parts
you can download ingersoll rand tool manuals and parts lists from
www.irtechpubs.com
Jan 22, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
Ingersoll Rand model 2100G air impact wrench turns without pressing the trigger when air is applied to it. What is causing this?
you will need to replace part # 2131-D565 inlet bushing assyand you will need part# 2131-322 inlet removal tool to remove the old assy.http://www.searspartsdirect.com/
you push in the tabs on each side of handle with tool and slide assembly out then push new assembly in until clip tabs click then all done.
Oct 27, 2011 | Ingersoll Rand Composite Air Impact Wrench...
It will not operate. I have tested the switch and the motor does not look ar smell burnt
Remove the motor brushes and check to see if it is worn. Check for voltage on the brush holder tube. If you have no voltages trace the wires from the electric source and switch. If you have voltage it is your brushes or armature coils. You can purchase parts from the below link.
http://www.ereplacementparts.com/milwaukee-907520-ser-239a-impact-wrench-parts-c-131_5120_5406.html
Apr 27, 2011 | Milwaukee 9075 20 Impact Wrench 7A 3/4 Sq...
Ingersoll rand impact gun 232TGSL street leagal gun runs in either direction wothout using trigger
YOU MIGHT HAVE A PROBLEM WITH THE THROTTLE VALVE SEAL ITEM #3 (O-RING) OR A STUCK THROTTLE VALVE PLUNGER ITEM# 5. TO ACCESS THESE PARTS YOU WILL NEED TO REMOVE THE INLET BUSHING ITEM# 6.
FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC.
Part Listing Order Page
Feb 22, 2011 | Ingersoll Rand 1/2" Super-Duty Impact...
Have a Ingersoll Rand 2135 ti impact wrench with a trigger that sticks in. Don"t know if it needs a spring in the trigger part or if there is another problem. Took it apart and cleaned it and oiled...
i have the same problem, and a fellow co-worker of mine told me about the problem. here it is.. on the handle there are two slots on either side, push them in and the air inlet assembly should pop out along with a broken tiny metal rod.. this rod connects to the inlet valve and turns on and off ur impact wrench.. i have been looking for replacement parts but cant find any.. hope this helps you and maybe help me too..
Nov 12, 2010 | Ingersoll Rand 2135Ti Air Impact Wrench
Parts for older eletric impact
Ohio power tool stocks some of these IR items, your model interchanges with model 8049.
Mar 15, 2010 | Ingersoll Rand Ingersoll-Rand 1/2 in....
Need exploded diagram of ingersoll rand Model 8049 electric impact wrench in order to order a planetery gear kit
Feb 22, 2010 | Ingersoll Air Tools & Compressors
Tools & Hardware - Others Logo
23 people viewed this question
Top Ingersoll Tools & Hardware - Others Experts
Mike
Eddie Tucker
Level 1 Expert
Lawrence Oravetz
Are you an Ingersoll Tool and Hardware - Other Expert? Answer questions, earn points and help others
