Question about JBL GTO14001 Car Amp
Bass level remote.
Hi
I have a jbl gto 14001 works fine but ive noticed when you connect the bass level remote when you tern it about a quarter of the way its at full volume witch is annoying because its to sensitive. is this a fault or just how it is?
    Problem Solver:
  • 19 Answers
Sound like a fault in the remote but try turnin the gain on the amp down a bit first
Posted on Jun 06, 2010
Why does my inline fuses keep blowing on a jbl gto 14001 amp
You need to calculate the amount of amps being driven through that fuse + the amount you need to feed the amplifier.
In my Volvo S40 and V70 I had no problems driving an amplifier of the rear power connector, but on my Honda S2000 however I had to create a different connection all the way to the battery line for a smaller amp (connection as in cables, condensers/filters and fuses).
Feb 18, 2016 | JBL Car Audio & Video
Disturbance while increasing bass in JBL SPYRO
I have a similar problem. You need to open your subwoofer and check if the subwoofers cone cloth is torn. If it's torn you can recone the subwoofer and it will work fine. There are solutions online to fix the cloth using regular synthetic mix cloth but i don't know if it works. Try removing the cloth to see if it sounds better.
Jun 03, 2013 | JBL Spyro Computer Speakers
I have a JBL venue sub10 subwoofer. I noticed a couple days ago the bass level seemed very high (speech had alot of bass) I tried to turn the volume level down on the back of the unit as usual and it had...
Hi well i would think that perhaps a capacitor in a cross-over network may have failed? What top do is open up the speakers and locate the capacitor, and inductor, cross-over network, that's the part that splits the frequencies to each speaker, hi, mid, bass, and simply replace the capacitor "On Spec" as it were, this or simply replace the entire cross-over network? this may help. It's worth a shot anyway? It also may simply be a bad speaker? again replace "on spec".I don't think from what you describe that you have "Overlooked" anything at all, it's just bad luck.
"on spec' simply means to replace without thinking about it....
Sep 26, 2011 | JBL Venue SUB10 Subwoofer
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
JBL GTO 301.1ii protect mode
Hello roets81,
Check the voltage at the amp. It's possible that the voltage is either too high (above 16V) or too low (below 8.5V). Also make sure that the amp case is not grounded. If these check out OK, the most likely cause is that the amp itself is defective and requires service.
Hope this helps.
May 27, 2009 | JBL GTO 301.1 Car Audio Amplifier
JBL EON15 PA Speaker problem
check the wire terminals under the cone by the spider and make sure that they are both still connected
Apr 16, 2009 | JBL GTO Series RLC Amplifier Accessory -...
Jbl gto 75.4 right channel not working
Hi
It's rare that 2 channels will fail simultaneously, are you sending 4 signals to the amp or just 2?
If you are sending just 2, perhaps the problem lies before the amp in the cabling to it, or the output from the headunit. If you are sending 4 signals then there may be a fuse in the amp that drives 2 channels out of the 4. Of course this may be the case should you just be sending 2 signals.
Dec 25, 2008 | JBL GTO75.4 Car Audio Amplifier
Jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
Dec 21, 2007 | JBL BP1200.1 Car Audio Amplifier
Bridge jbl gto 600.1
it will over heat the amp posibly blow it.....becareful
Nov 09, 2007 | Rockford Fosgate Power 1001BD Car Audio...
JBL GTO14001 Car Amp Logo
143 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
