Question about Teac Audio Players & Recorders
I need to replace the main drive belt in an A-105 Teac cassette d
I need to replace the main drive belt in an A-105 deck. Are there instructions or diagrams available as to how to access the flywheel to position the tape?
  • 883 Answers
SOURCE: teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Posted on Jun 23, 2007
  • 9 Answers
SOURCE: Source For Replacement Belts
http://www.studiosoundelectronics.com/cassette.htm
http://www.turntableneedles.com/index.asp
Posted on Oct 27, 2007
robotek
  • 1512 Answers
SOURCE: Drive Belts for AKIA Stereo Cassette Deck CS-M01A
still need help?
Posted on Feb 09, 2008
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
How to replace the belt on a Teac W-750r cassette deck
In all the years I have been in tape decks repair I have never seen one. You either have to work with an experienced Technician or do it yourself using common sense. Going to college gives you a degree and knowledge of parts it dos not tell you how to fix anything. That may be why I work on some Nasa Engineers tape decks.
Jan 06, 2014 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Getting belts for TEAC W-890R. I'm currently sitting here a home with a DEAD TEAC A-350 Cassette Deck -- DEAD because I was told you can get belts for it (I have since found out that is is NOT true and...
That is the state of conditions at Teac and they don't care about tape customer anymore. If you need belts for any unit it is simple to find the belt kit at Marrs Communications. They do not have he cheapest prices bu the you don't know what size you need and Fred took time to find his out. If you want to do it the other way you download a copy of the PRB cross reference manual and look up the belt type that goes into your deck. The you go to Ken's Electronics and order the belts online. This does not come with instruction of how to put them in. In my many years as a Technician working on all kinds of tape decks I have never seen an instruction to put belts in a machine- it is assumed that if you can not figure this out that you probably do not belong in the machine. In cases where belts are not in place sometimes the parts layout diagram can help you determine how they go in.
I am an ex Teac Lead Technician from Chicago.
Aug 25, 2013 | Teac W-865R Single Cassette Deck
Teac v 370 cassette deck belt
You need only to measure the diameter of the belt in mm. Then enter "cassette tape belt ??mm" into Google. They are universal. If you're measurement comes to say 53mm then a smaller belt of say 50mm will fit it.
Mke certain you make a note of how it fits before removing the belt.
Nov 13, 2012 | Audio Players & Recorders
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
Instructions to replace belts on teac cx650r stereo cassette deck
The replacement of belts on any deck requires you to dismount the transport section and take thrust plate off as well as other mechanical parts to get to the belt location. It is at this time that the reel table should be removed and rebuilt as the take-up torque due to old felt will be excessive and you don't want to have to go in again. Oiling of the Flywheel bearings is also good to do at this time.
If you can not do it I work on deck as Skywave Tape Deck Repair near Chicago. That is one option. There is another service provider in New Jersey.
Jan 22, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Oct 08, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
97 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
