Question about Whirlpool AWM5145/2 Front Load Washer
Machine not draining
Why is my machine not draining it is also makeing some strange noises and it is only 3 years old
  • Whirlpool Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinemachine not draining - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 05, 2010
My washing machine has started making a noise when it should spin, and doesn't drain on the spin. It Starts the cyle ok, and drains, but the problem is when it spins. It isn't spinning at speed - it is...
Either your pump or filter or outlet hose is blocked Clean out the filter/pump and make sure the outlet hose is not blocked.
Difficult to help without make/model??????????
Jan 27, 2011 | Washing Machines
The washing machine is a wma52 and has a 1 year old new pump on it last year. it will not drain the water away but is not making any strange noises like before. is it the filter?
hello, check the filter if ok then check the drain hose that connects from the pump make sure it's not kinked does it connect to plastic pipe and straight out through the wall make sure this not blocked.if it connect under the sink make sure your sink not is blocked if the pump has failed check the wiring to the pump hope it helps
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WMA52 Front Load Washer
Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Feb 07, 2010 | Washing Machines
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Strange noise upon initial start-up
try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Jun 01, 2009 | Whirlpool LHW0050PQ Front Load Washer
Motor makes loud rattling noise during rinse cycle
could be the coupler and the only way to truely check it is to take the pump, then the motor off. But it seems strange to me that you say it works fine. Is it spinning? usually when the coupler breaks it sounds horrible and usually will not spin but it will drain.I would check the coupler again.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Strange ogject in PS3 game console
removing the strange object would be the first thing.
secondly, would be to put it up out of your sons reach.
Finally would be to find out your warranty, you,ll be needing it.
Mike @ compurepair.
Feb 25, 2008 | Sony Playstation 3 (PS3) Console
Whirlpool AWM5145/2 Front Load Washer Logo
113 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
