Question about Goldstar DH504EL Dehumidifier
Dehumidifier compressor hot to the touch. No water is collecting. Exhaust air from fan is cool.
Illeagle
  • 525 Answers
SOURCE: Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
22yooper
  • 828 Answers
SOURCE: GHD30 dehumidifier completely dead
If any machine is completely electrically dead it is a sign that there is no electrical voltage getting through to operate it. Using an electric meter it is a relatively easy task to find the point of differential voltages which would indicate where the open circuit is located. The blue green fluid found is from copper oxide and is not necessarily indicative of a refrigerant leak. Oil present would be an indicator of a refrigerant leak.
Posted on Nov 17, 2008
  • 252 Answers
SOURCE: dehumidifier throws off hot air
Yes! A dehumidifier is an entire AC system in one box. First the air passes thru a very cold coil causing moisture in the air to condense and run away. Then the air is re-heated thru a hot coil (the other half of the AC) and blown back into the room. The net result MUST be a net increase in temperature because of the heat added by the mechanical process.
Posted on May 17, 2009
heatman101
  • 43501 Answers
SOURCE: My Dehumidifier stops working and it doesn't turn on
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 03, 2010
heatman101
  • 43501 Answers
SOURCE: Goldstar dehumidifier won't run
Sounds like this unit developed a freon leak and that will make it run hot like that...cheaper to replace it then to repair...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 18, 2010
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
Compressor and fan are running. no water collected from air.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
May 30, 2011 | Maytag M3DH30B2A Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
It runs but does not take humidy out of the air. There is no water in the tub. The compressor seems very hot to the touch. I cleaned the filter. The fan motor is working fine. What do you think the problem...
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Aug 27, 2010 | Fedders Dehumidifiers
New dehumidifier runs very hot...back of unit is extremely hot to the touch, and the space around it becomes uncomfortable to live in. With hot summers like this one (and maybe future ones?) we don't need...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the compressor is toast...
There can be many reasons why a dehumidifier will not work or collect water.
heatman101
Aug 23, 2010 | Haier 45-Pint Dehumidifier
Compressor hot but no cooling of air
Check that the cooling fan is running,before you burn out compressor.
May 05, 2010 | Frigidaire FDF70S Dehumidifier
Runs but does not collect water.
compressor run but gas charge not enought
so it not very cool,and no water come out
Aug 23, 2009 | LG LHD45EL Dehumidifier
Fan runs, but compressor does not start
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Goldstar DH504EL Dehumidifier Logo
968 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Jerry Greenberg
Jerry Greenberg
Dan Webster
Dan Webster
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
