Question about Weber Summit Platinum C4 (LP) Grill
Grill will not ignite even with manually trying
Grill will not ignite even when i try to put a lighter in the lighting hole and the tank is full.
  • 494 Answers
Can you hear or small gas? It's possible to may have turned the propane tank valve on too fast. Close the tank valve, disconnect it, then reconnect it. Slowly turn the tank valve back on and try lighting it again. Hopefully this is your solution, but let us know if you need more assistance. Or check out my Tips & Tricks for gas grill lighting problems, just click on my user name and scroll down to my Tips & Tricks and see if any of those solutions help.
Douglas
Posted on Jun 04, 2010
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
How to you start it
Grill should have a push button igniter located on control knob panel. The ignitor requires a battery, usually AA. Remove the cap and put in battery. Make sure propane tank has propane and turn on. Make sure all connections are tight. You can also manually light it by going through the view hole located at bottom front or side. Make sure your match or lighter is in and lit before turning on gas.
Jun 20, 2011 | Char-Broil CharBroil 4637318 Grill
Grill wont light
Hi there, can you let me know if it will light manually with matches,lighter or manual lighter. I'm trying to work out where the problem may be (gas or ignition). If you lift the gas tank is there liquid inside it.
May 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
Can not light gas grill - Weber 8006 Have done all suggested thing such as full tank of gas, regulator checked, check for spider webs. No gas seems to be reaching burners.
This grill is definitely worth fixing. I have had similar problems with several weber 8006 grills. It is usually something obstructing or diluting the flow of fuel. If you have a new tank and your igniter is working (you have tried using a propane hand-held lighter, I assume) then it seems that it must be either the hose/gas line or the burner tubes. I would first check the main tubes and cross tube carefully for places that are rusted through. Holes can lower the pressure in the tubes and make them difficult to light (try just turning on and lighting the front burner). I would then clean the tubes at the spider trap/air vent end, which is nearest the propane tank. The spider traps, if you have them, are little plastic cages and the edges snap together. You can use a vacuum to gently clean out the tubes. If this does not work, you can buy or borrow a similar, but working hose. As they say, "it is always the last thing you try that fixes the problem".
Jul 12, 2010 | Weber Performer Grill
Burner won't turn on
The first question I have is the flame size good on the 2 burners that did light? If the flames are smaller, then you might just need to turn off the tank and disconnect it, then reconnect it and very slowly turn the tank valve on again. You might have turned the tank valve on too fast causing the excess flow valve to close and only give a trickle of gas through. On the other hand, if the flame size was good on both burners, then your igniter may not be lighting the rear burner, but typically if the other 2 burners light, the 3rd burners lights off the others. Did you try lighting the 3rd burner manually with a lighter to see if it was getting gas? If it lights manually, then the spark igniter may be your problem. It's also possible the rear burner has clogged holes from rust or drippings and is difficult to light. Without seeing it, it's just the process of elimination til it works. Try all those things and see if that gets it going for you. Check out my tips & tricks on gas grill lighting for more detailed info. Click on my user name and scroll down til you find it listed on my profile. Good luck. Douglas
May 15, 2010 | Weber Genesis Silver A Grill
Own a charmglow gas grill 3 burner, having trouble igniting burners will not ignite, how do you match start
I have used those long-necked lighters as a temporary thing. You can buy replacement igniter kits at Lowe's/HomeDepot/similar, and they are easy to use. I hate to admit it, but I have taken the igniter out of the side burner that is attached to the grill and used it, until I bought a replaement. Match starting is a less than favorable option, as you are putting your hands and face in a bad place, but if you just have to do it, remove the grill grate over the burner that you intend to light. Get your fire source to the burner, and turn the gas on low. If the burner doesn't light pretty quickly, remove the fire source,shut off tha gas and wait several minutes with the lid still up for the gas to dissipate. You don't want to be trying to light the grill and have it flash on you. Most grills have an opening at the rear if the grill for manual lighting. Even so, the long lighters are waaaaaay better than the old kitchen match. I'm sure that you know, but always have the lid open when lighting the grill. (I just had to say it!)
Hope that this helps...really!
Best regards, --W/D-- please feel free to rete this solution! Thanx!
Jul 29, 2009 | Grilling
Grill no longer producing good heat
read manual...possibly triggered propane safety bypass. Close tank, Turn OFF all burners, disconnect tank. Open one burner for 1 minute and turn off again. Reconnect tank. NOW OPEN tank slowly, all the way. Turn on first burner and ignite with starter or light through port hole manually. Hopefully works better.
Mar 25, 2009 | Weber Genesis E-310 Gas Grill
Ignite prob
You've got two different things going on.  First - the type of igniter used on your model does wear.  I have had mine for over 10 years and have gone through 3 such igniters - and I grill nearly 3 times per week over the 25 week "grilling" season where I live. Spring for the $12 part and just replace it. The other issue sounds like a clogged cross-over system.  I would remove the burners, including the cross-over bar on the far left side that connects them.  Clean the exterior with a stiff steel/brass brush and the inside with a bottle brush.  Make sure all the holes are clear to allow gas to flow easily - use a wooden tooth-pick to do this to make sure you don't change the size of the holes! Put that baby back together and I think you'll find you'll be good as new!
These grills are great.  Now, if Weber could only fix the uneven heat problem between the left and right side I'd REALLY be happy!  (I wish they would even just admit there IS a problem!)
Good luck and happy grilling.
Mar 03, 2008 | Weber Genesis Silver B Grill
Weber Summit Platinum C4 (LP) Grill Logo
209 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
