Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Cutting blade barring ***
The barring and hub that hold the blade.
    Brigadier General:
  • 3,911 Answers
I think that part is called a mandrel, pulley on top and blade on the bottom.
Generally you remove the deck, take off the deck belt, take off the covers, take off the blade, remove the bolts holding the mandrel to the deck. Get a new mandrel at a sears store or small engine repair shop and reassemble in reverse order. May want to do them all while you are at it and save yourself duplication of work next year.
Posted on Jun 07, 2010
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
Chain came off, how do put it back?
Remove the cover. Loosen the two bolts that hold the chainsaw bar. Slide the bar back (it has a long slot for adjustment) until the blade can be lifted out of the track and sprocket. To replace the blade slip it onto the sprocket and the bar. You must hold the bar level while replacing the blade. Be sure the blade fits into the track around the bar. Once in place double check the placement on the sprocket and pull the bar outward until all the slack is removed from the chain blade. Holding firmly, (it would help to have someone assisting) keep the pressure on the blade and bar while replacing the bolt nuts. Then replace the hood cover. Smile.
Sep 27, 2014 | Worx Jaw Saw Replacement Saw Chain
I want to remove the blade bar of a Morrison Vantage Motor Mower to replace of the swivel blades. The bolt holding the bar to the direct drive shaft comes out Ok but the bar won't budge....
Most blade bars have to be driven of by hitting it with a hammer. They are spun on and off. Sometimes they go counterclockwise.
Oct 16, 2013 | Garden
I'm having problems unbolting the fan hub from the waterpump
I find that If i place a flat bladed screw driver under the nut next to the one I wish to undo and lay it across the hub I have an effective bar with which to hold the hub as I undo the bolts/nuts. Undo 1 and then move onto the next one and repeat the process.
Mar 14, 2013 | Cars & Trucks
Blade won't stay tight
if the blade keeps coming loose replace the hub that holds the blade in place
Jun 26, 2012 | Toro Garden
Need to replace to old blade with a new one on a rolux magnum laser lawnmower but don't know how the remove it
Disconnect the spark plug wire and ensure that the plug cap is some distance from the spark plug.
Remove the center cover cap (Pry off) and then remove the mounting bolt by turning it Counter clockwise while holding the blade to prevent rotation. Pull off the old blade and remove the center hub housing from the old blade. Transfer the center hub housing and install the new blade. Tighten the bolt CLOCKWISE while holding the blade until it is tight. Make sure you use a 6 point socket! Using a 12 point socket will result in the socket slipping and personal injury.
Re-connect the spark plug wire and your ready to mow again.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Garden
1985 Silver Spirit. Gates 7270 belt to smog pump. Will not go over fan blades. Which bolts to romove to remove fan?
hold fan belt with both hands as if stretching a rubber band.place one end of belt over a fan blade all the way down to the hub.loop the other end over as many blades as length allows.''leap frog'' over remaining blades as necessary.if that doesn't do,there should be 4 bolts holding fan hub to it's mount on water pump spindle
Sep 26, 2009 | 2006 Rolls Royce Rolls Royce Silver Spirit
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Lasko fan
I can tell you how to take the fan blades off your Lasko Model 3723 fan, but you might not be able to use it on your other fan. The reason why is that the motors, although similar, may not have the same diameter shaft.
Of course, you should have the power cord unplugged from the AC outlet before removing the front fan grille and placing your hands on the blades. Safety first!
The fan blades and hub are a single unit that stretches to fit onto the motor shaft. There is no setscrew at all. Take any sort of metal bar or tool such as a screwdriver or pry bar and carefully lever the hub off the shaft by pressing your lever to lift the hub a small fraction of an inch on each side, working the hub slowly upwards against the long vertical bars that support the motor. If you have reasonably strong hands, you may be able to pull the hub toward you by placing your fingertips under the edge of the hub and pressing with your thumbs against the vertical support bars as needed. It's not too difficult to do.
Aug 15, 2008 | Lasko 3723 Floor / Box Fan
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
114 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
