Question about Brother HL 5140 Laser Printer
HL5140 - On power-up goes to a blinking red status indicator and the toner/drum/paper lights blink yellow. Is this a main board failure?
  • brcrull Jun 04, 2010
    Any other ideas? I do have working printers of the same model to use to test and/or eliminate possible problems.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Main PCB failure is when both status and toner light are on in yellow,so this is not a main PCB failure. Please try these step by step instructions to resolve this issue:
  1. Turn off the printer power switch.
  2. Take out the DIMM (Dual Inline Memory Module) from your printer, if you have a DIMM installed.
  3. Wait a few seconds and turn the printer back on.
  4. Try to print again.
    If the error still remains, press the Go and the Job Cancel button together to check the error status referring the LED indications below.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 04, 2010
    No DIMM that I am aware of. When pressing the two buttons the tonor light remains yellow. I again tried replacing the toner with a cartridge from a working unit with no success.
    Thanks
  • Rylee Smith
    Rylee Smith Jun 04, 2010
    The Toner LED is on in yellow and the Status
    LED is on in red indicates fixing unit failure.
  • 503 Answers
The toner cartridge is completely empty and needs to be replaced.
http://downloadcenter.samsung.com/content/MM/200607/20060725132848031/um_clp-300_html_eng_051220.html
Please post your feedback and Vote if the problem resolved as per your satisfaction.
    We have more than one of these printers and I had swapped the toner cartridge with a working unit. It did not make a difference. No toner low indication prior to the problem.
Powers on then off with 4 red binks then 2 amber?
A blinking red and yellow Status LED will indicate an Error Code that can help determine the cause of a circuit
failure.
• The number of Red blinks indicates the value of the (tens digit) of the Error Code.
• The number of Yellow blinks indicates the value of the (ones digit) of the Error Code.
Example: If the Error Code is "37", the LED will continuously blink Red three times, followed by blinking Yellow
seven times.
25846923-00ymvd0zfh3oypxbgkhcneuw-4-0.jpg See the following for a list of Error Codes.
To perform a System Reset, press and hold the Power button for 10 seconds. Or, unplug the set for 10 seconds
then restore power.
http://electro-medical.blogspot.com/
Sep 02, 2015 | Mitsubishi WD-73638 3D-Ready DLP HDTV
Why is tv blinking 4 red lights and 8 yellow lights
An error code of 48 indicates a main power board failure. There is a short down the 3.3v or 5v switched supply.
recommend replace main power board.
part# 934C409001
see the following website:
http://www.shopjimmy.com/mitsubishi/wd-73c11?cat=59&q=WD-73C11&tv_models=Mitsubishi+WD-73C11
Jul 01, 2014 | Mitsubishi WD-73640 73-Inch 1080p...
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
I replaced the fuser in a Brother HL5170-when I turn it on, all 4 lights are blinking. What might be the problem?
This is what's called a Service Call, meaning the machine has experienced a problem that it doesn't think an end-user can support.
According to the manual:
"Push the Go switch and the Job Cancel switch at the same time during the service call and hold them. And then push the 2 key additionally to show the service call type by LED combination."
Which I'm assuming means press and hold the two buttons, then press them both again.
The combination of the LEDs tells you where the problem is:
RED Status +:
Toner LED = Fuser (Fixing Unit)
Drum LED = Laser
Paper LED = Main Motor
YELLOW Status +:
Toner LED = Main PCB
Drum LED = Engine PCB
Paper LED = DIMM
All of which are expensive parts and also expensive repair.
Oct 12, 2010 | Brother HL 5170DN Laser Printer
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Feb 02, 2010 | Brother HL 5250DN Laser Printer
New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Jul 22, 2008 | Brother HL-5240 Laser Printer
Printer problems
All four lights flashing indicated a problem only a service center can repair.
Press the Go button and a new set of indicators will appear.
The yellow toner light only indicates a fuser unit failure.
The yellow drum light only indicates a laser unit failure.
The yellow toner light AND the red paper light indicates a main motor failure.
The red paper light only indicates a PCB failure (Printed Circuit Board).
The only thing you can do at this point is to actually UNPLUG the power cord for 24 hours and then retry or if that fails take it to a service center or better yet go pay the $89 for a new unit.
Hope this helps.
Dec 25, 2007 | Brother HL-2040 Laser Printer
B4100 - Yellow Light
U can have stuck a little piece of paper, that it mess whit some sensor. Try to open the Oki, push the drum unit out and watch if there is no paper stucked.
Nov 26, 2007 | OKI B4100 Laser Printer
Brother HL 5140 Laser Printer Logo
132 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
