Question about Dell Inspiron 1545 Notebook
Error code 2000-0146
I get a hard drive error code 2000-0146
    Guru:
  • 868 Answers
You Hard Drive is About to fail soon back up all your data and have your HDD replaced ASAP, the longer you use the Hard drive it just may fall to a point tha you get the S.M.A.R.T error which is an HDD error as well replace you HDD asap ^_^ back up data if possbile ^_^
Posted on Jun 05, 2010
  • 3940 Answers
SOURCE: i get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
SOURCE: Error code 2000-0146
its a hard drive error you have a bad sector in the drive its defective. If its still under warranty call dell hardware support with the error code. If not buy a new 2.5" drive they are not to spendy. I just replaced mine with a 250g 7200 and my computer works great now.
Posted on Jul 31, 2009
antiochpc
  • 1314 Answers
SOURCE: dell inspiron 1520 error code 2000-0146
Yes, it is a hard drive issue and there is no fixing it temporarily without losing your data. The best thing to get your data is to get a USB enclosure for the type of drive it is (if it's a sata drive or a pata drive) or get an adapter that's an all in one (for 3.5, 2.5, and SATA). Then you hook your failing drive up to the converter, put it in the usb port of another computer and then it will show up as another drive that you can open and explore.
Posted on May 27, 2009
techabhishek
  • 66 Answers
The error code 4000-0146 basically refers to an issue with the HDD.However, the error is fixable. If you running on Windows XP, boot to the Recovery Console using the WinXP CD. Or the Windows Recovery Environment if you are using Windows Vista/Win7 and choose command prompt from the WinRE menu. Run chkdsk /r command in the recovery console or command prompt. The command will take approx 20 -90 mins depending on the errors and would finish with a log. Reboot your computer and see if you can boot through your OS normally.
Posted on Mar 19, 2010
  • 629 Answers
SOURCE: error code 2000-0146 do i
that error actually refers to a hard drive issue/failure. You may attempt a reformat and reinstall, but if it fails, you can proceed to get a new hard disk. You can get in touch with Dell for warranty replacement if applicable, or order a new hard drive. You may then decide either to get the same capacity or upgrade to a higher capacity drive.
Posted on Sep 03, 2010
When computer boots up I get this error code A disk read error occured code 0F00:0666
A bad hard drive or the boot sector (the map of the hard drive contents) has an error.
You have two choices. If you run regular backups you can do a full restore including the boot sector, if not, you'd have to format the hard drive and lose your data. Then reinstall Windows and start from scratch.
The other option that loses your data, as well, is replacing the hard drive if it's defective.
Mar 09, 2014 | Seagate 500GB Barracuda 7200.12 SATA...
Wont let me play says send error report
Well most xbox units in the US will have a code with the xbox error report, you need that code when calling microsoft customer support at 18004myxbox. If it goes to a black screen and gives an error code here is a list of known codes.
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
If the xbox is telling you something is wrong via the rings of death just make note of what the colors were and where they were.
Sep 10, 2010 | Microsoft Xbox 360 Elite Console
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Nov 09, 2009 | Dell Inspiron 1525 Notebook
Resuming windows
Guess the error code is that of the diagnostics in built in the dell systems.
This error code indicates a problem with the Hard drive. It can be resolved by reseating the hard drive and the optical drive. Kindly look in to the manual and look for the location of the hard drive. It will have 2 screws which needs to be removed after which the hard drive can be pulled out. Optical drive will have one screw embedded deep inside.
Place the hard drive and the optical drive back in its place and then test for the error code.
Please turn off system and remove the battery and the AC adapter when performing these steps.
Sep 13, 2009 | Dell Inspiron 1521 Notebook
Getting error code 04C300 00310000
Hi;
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
May 26, 2009 | HP DesignJet 1050c InkJet Printer
Please help me ??? system error
System Error: 04Cxxx
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Press ENTER and switch the printer OFF. Remove the Hard Disk
EIO card.
n If this Error Code disappeared after removing the Hard Disk
n If this system error continues to appear after replacing the EIO
System Error: 0000D8 XXXXXXXX (Non-Continuable)
Problem
Description:
External Library Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you.
Apr 06, 2009 | HP DesignJet 1050c InkJet Printer
Dell Latitude D600
It is the Hard drive on the system. Hard Drive is failing. Another Error code for the Hard Drive is Error Code 7. Check BIOS setup if the system still detects the Hard Drive as well. You may want to consider changing the Hard Drive on the system.
Nov 09, 2008 | Dell Latitude D600 Notebook
Code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Jul 29, 2008 | Dell Inspiron 1150 Notebook
Error codes
This type of error code can occur when installing Windows 2000, if there is some sort of hard drive confliction. If you have multiple hard drives in the computer. Please unplug all other hard drives except the MAIN drive that you are installing on, if the errors still occurs you may want to try installing to a different hard drive as your main drive, or replacing the IDE or SATA cable.
Another option to consider is that format did not complete correctly, you may want to viist the website of the manufacturer of the hard drive you are installing on and retrieve the utility to perform a Low-Level format on the hard drive - this will erase any and all data on the drive.
Jun 18, 2008 | ASUS P4T-M Motherboard
Dell Inspiron 1545 Notebook Logo
2,192 people viewed this question
Alun Cox
