Question about Gateway FPD1975W 19" LCD Monitor
I have a Gateway monitor...model FPD1975W TFT LCD HD ready...that won't show the picture...even during post. I tried both VGA and HDMI inputs...the power button turns blue...and when I toggle the input button.. once in awhile a picture will flash and I can see windows but it goes off right away! ??? any help would be greatly appreciated. Thanks
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 05, 2010
Where is the microphone
That model does not have a built in microphone, you will need to get an external mic and connect it to your computer.
May 08, 2012 | Gateway FPD1975W 19" LCD Monitor
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
When i plug in my Gateway FPD1975W TFT LCD Monitor, the screen stays black and the power button blinks. This goes on for hours without doing anything else. Suggestions?
If you have this connected to a computer and it happens,make sure the fault is not with the graphics card or port first. Test the monitor on another computer or laptop. Test and check the VGA cable.
If this is not the problem (ie the monitor will not work on another computer and another monitor will work on your computer), you are probebly having power capacitor problems and the monitor needs replacing.
This link will explain more
View sonic monitors were particularly known for this problem
Aug 16, 2011 | Gateway FPD1975W 19" LCD Monitor
I have a Gateway FPD1975W TFT LCD Monitor and the power button is blinking blue. The computer is on but no picture. Need assistance
Hello, it may not be the monitor. It could be that the pc is not talking to it. To check this try another monitor. If it doesnt work on that one,its the computer thats faulty, usually the video card. If however it does work, you have a faulty monitor. They can be fixed or replaced. Or you could try your monitor on another pc, either way you will find out for sure. I hope I have helped.
Mar 28, 2011 | Gateway 19" Widescreen Flat Panel TFT LCD...
I have a FPD1975W tft LCD monitor and the screen will blink on but then shut off. the power button still shows on though. i've checked all connections and did a cleaning as well but cant get the monitor...
The description points to the inverter board which energizes the back lights behind the screen, and is on the verge of failure. The cause is usually bad capacitors, the board will need to be replaced or a attempt to repair the existing one. If a professional gets involved the parts and labor can run high.
Feb 09, 2011 | Gateway 19" Widescreen Flat Panel TFT LCD...
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
FPD1975W monitor issues
Check your video card. it may be a bit lose in the port. Also, you should reinstall your video card drivers as well. make sure your monitor is plugged into the correct video card AVI/dvi input port.
Jan 27, 2009 | Gateway FPD1975W 19" LCD Monitor
MONITOR WONT STAY IN DVI MODE
Did you try the card in your friends machine? That would be the next step. The card could be going bad.
Feb 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
280 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
