Question about HP Pavilion dv4000 Notebook
Punctured cable the data cable has been puctured, will this be expensive tpo repair?
  • One Million Network Inc
    when you say th data cable
    do you mean
    the cable the takes data to the laptop display?
    Habit-Forming:
  • 92 Answers
Well you'd have to make it known which cable it is.
KJ
Posted on Apr 17, 2008
What type of roof ? EPDM or TPO
My preference is PVC but TPO would be my second choice. EPDM is old school, more expensive not as good. All need good drainage add drains to eliminate any ponding areas.
Aug 25, 2016 | Heating & Cooling
How to splice repair on shielded o2 sensor wire
Hello
Best to replace the cable. Not very expensive to get. A bad connection can damage your catalytic converter, when mixture runs rich at all times. Repairing a cable may also send wrong data to the computer.
Jul 11, 2014 | Vehicle Parts & Accessories
Frig freezer got puctured and the gas leaked out.-solution?
u will have to call someone to repair the leak and recharge with gas
Apr 08, 2014 | Samsung Refrigerators
Iwas cleaning refer and punctured the back. I hear air . what to do?
That is not air you have punctured a Freon line and could be expensive to repair depending on where
Jun 02, 2013 | U-Line 75R Refrigerator
I think my husband punctured the interior (released the freon?) when he was defrosting (chipping away at ice. Can this be fixed?
It can be fixed, but not by your husband, and I say that assuming he is not EPA certified in refrigerant handling. This is definitely a major repair, one that should not be attempted by the average DIYer. What needs to be done, is to evacuate what refrigerant is still in the system, replacing the evaporator coil that your husband punctured as well as the gas dryer, putting the system in a vacuum to check for any leaks, dehydrating the system, and then adding the exact amount of refrigerant for your model. Now this is a very very basic procedure, ive left out many critical and necessary steps, but it is just an idea of the refrigerator repair that is required for your problem. I hate to say it, but you've just learned a very expensive lesson on how not to defrost your freezer.
Oct 26, 2010 | Scotsman RFE33 Compact Refrigerator
I punctured a hole into the freezer box and all the free on (I guess?) blew out. Now it wont get cold. Can this part be replaced?
It can be repaired but it is an expensive repair if it is an older unit you may be better off to replace it.
Sep 04, 2009 | U-Line 15R Compact Refrigerator
Freezer puncture.  I punctured the liner to the freezer, creating a slight hole that emitted a vapor (presumably freon).  Must I repair it?  How do I repair it?
The freezer coil where you punctured is made of aluminum and there's not cheap way to fix it , but if the refrigerator is in good conditions you can replace the coil or get somebody to do it ( it is an expensive job).
Aug 15, 2009 | Whirlpool Refrigerators
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
The rubber ring/seal has been punctured
heardof people repairing with limited succes with bicycle tire repair kits, the true solution would be to replace theboot, can be a abit of a pain in the but to get on but with time and some patiens it cann be done aprts problay 75-90 bucks
Mar 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak repair Samsung window air conditioner
Modern window units intentionally do not allow the water to drain directly, they want the fan blade to sling the water on to the condensor (the coil that is outside) to aid in cooling actually helps the unit cool better in high outside temps, it also evaporates it this way, depending on where the hole was drilled it may be able to be repaired, if it was just a copper tube it will be less expensive than replacing the whole coil. Since its a relative inexpensive unit anyway the labor and freon may be more than its worth. Lesson learned dont drill a hole in the base it lowers it's efficiency and can lead to a punctured freon line.
Sep 29, 2007 | Heating & Cooling
HP Pavilion dv4000 Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
