Question about Porter Cable C6110 150 PSI 25 Gal OilFree Induction Vertical Portable Compressor
Porter cable stand-up air compressor starts but air won't fill up
I have a Porter cable air compressor model number CPFC2TV3525VP. it runs fine but the air won't fill up to the tank or the gauge won't go up
  • Anonymous Mar 27, 2014
    After the tank fills the compressor cycles on and off while leaking air
  • 59 Answers
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Posted on Jun 06, 2010
Porter cable compressor electrical smell won't run
wow
Check motor and pressure switch for erosion, electrical strikes in plastic
Replace if bad
Dec 31, 2012 | Porter Cable Cable 4.5 Gallons 150PSI Job...
My Porter Cable Job Boss compressor won't shut off. It builds up pressure but just continually runs.
Pressure switch - replace as soon as possible
Overpressure would be possible in that tank - it is dangerous !
Oct 20, 2012 | Porter Cable 4 5 Gallons 150PSI Job Boss...
What type of oil do I use in model CPLDC 2541S
If you mean the CPLDC2541S (Porter Cable air compressor), you need to fill it with an air compressor oil. The recommended weight is SAE-30 (API GC/CD heavy duty motor oil). You can use a SAE-10 oil in harsh winter condiions. The manual is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/20237/PORTER-CABLE-Air-compressor-L0309172 .
I hope this helps.
(note standard motor oils designed for cars are not appropriate for a compressor.)
Jun 21, 2011 | Porter Cable Garden
Need a rod for an oil run porter cable air compressor model c3151
Ok, the post shows 2 model numbers, so I will provide links for both. Be sure to only pay attention to the model number you actually have.
For a model C3151, an oilless compressor, the only way to get the connecting rod is by buying a piston kit, there is no individual replacement. KK-4835 is the part number and it runs about 50.00.
It can be purchased here.
http://www.ereplacementparts.com/piston-cylinder-and-ring-replacement-kit-p-58708.html
Now if you have a C3551, an oiled compressor, the entire Eccentric Rod Assembly will have to be replaced. The part number is Z-D22207 and it runs about 100.00.
http://www.ereplacementparts.com/assembly-conrod-eccentri-p-62701.html
I hope this helps.
Dec 04, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Job boss compressor wont run
have you checked the motor reset
will be on the motor
May 10, 2010 | Porter Cable Cable 4.5 Gallons 150PSI Job...
Rust in air compressor tank
first you need to remove the tank and get rid of the rust with a rust kill agent, vinga or chemical type with corrosive converter, then liquid paint the inside of the tank, swilling the paint inside and leave to drip out. then find a high pressure line filter, these are a solid filter and put in line. to stop this happening again to the tank you can also put a drop valve in place and when not in use press to release the air inside as this is what rusts the tank. but after the restoration it should be fine without a filter.
Jan 03, 2018 | Porter Cable Tools & Hardware - Others
Porter Cable C6110 150 PSI 25 Gal OilFree Induction Vertical Portable Compressor Logo
635 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
