Question about Holmes Products HPF650-U Stand (Pedestal) Fan
Where can i find a three way switch - Holmes Products HPF650-U Stand (Pedestal) Fan
    Scholar:
  • 130 Answers
You can go online 'www.mcgillelectrical.com'
Posted on Jun 06, 2010
I want to replace a dimmer switch, with a new one. my new dimmer switch has two black wires and one green. The wires inside my wall has three black wires. How do l connect them?
Assuming you mean the old dimmer switch has three black wires. The old switch is a three way style switch and your new one is a single pole. You will need to take it back and get a three way dimmer switch.
Dec 16, 2016 | Electrical Supplies
Replace sealed 1950s three-way switch
https://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Sep 16, 2015 | Electrical Supplies
Pair Siemens dimmer 300w sockets
You need THREE-WAY SWITCHES to be able to use them in tandem. SPDT (Single Pole Double Throw) switches.
You cannot install two ONE-WAY switches (SPST - Single Pole Single Throw) to switch from two loacations.
You CAN, however, use ONE Three-way dimmer on one end of the room, and one Three-way 'regular' switch on the other, if dimming from just one place is adequate for you
Oct 10, 2014 | Electrical Supplies
How do i wire a three way switch
There are several ways to wire three way switchs, depending on which box the power goes to. Check ou this link for diagrams.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Sep 27, 2014 | Intermatic Home Settings Three-Way In-Wall...
How to wire 3 speed switch
Not sure of your application, but in most cases a three speed motor has two sets of coils (one bigger than the other), and a three speed switch has three leads. Speed 1 uses the small coils, speed 2 uses the large coils and speed 3 uses both. The switch has one input (A) and two outputs (B, C). In the off position, none of the leads are connected together. In speed one, A-B are connected. In speed two, A-C are connected. In speed three, all three A-B-C are connected. With the help of a resistance meter you should be able to identify the switch leads easily. The small motor coil will have a higher resistance than the large motor coil. I hope this helps. Good luck.
Feb 12, 2013 | Electrical Supplies
How do i install a 3 way switch with 12/2 wire?
Three-way switches require a three-wire cable: the power wire, the neutral wire, and the traveler or switch wire.
The cable should also have a ground wire, or a total of four wires in the cable. The system also requires three-way switches. The switches are wider than regular single-pole switches and they have three terminal screws on the side (sometimes back) of the switch housing. Two terminals will be on one side of the switch housing; one terminal on the other side.
May 02, 2011 | Refrigerators
I HAVE A DIMMER SWITCH BUT NO MANUAL AND I THIN ITS MISSING A WIRE
A standard dimmer switch only needs two wires plus ground, just like a standard switch. If you are replacing a three-way switch with a dimmer, then you need a three-way dimmer switch (which has three wires). 4-way switches have 4 wires. Note, with 3-way or 4-way switches you have multiple switches controlling the same light, but only one of them can be a dimmer. good luck, Al K
Jan 19, 2011 | Garden
How to wire a cooper four way switch
As I describe the number of terminals, I am not counting the ground terminal (usually colored green.) A four-way switch has four terminals. Two are for two "travelers" coming in, and two are for "travelers" going out. One pair is at the top, and one pair is at the bottom. You only need to use a four-way switch if you are wiring three or more switches together to control the same light. In the case of three switches, only the middle one needs to be a four-way, with the first and third switches only needing to be three way switches. If you are only wiring two switches together, you only need to use three-way switches. However, you can use a four-way switch in place of a three-way switch by only using 3 of it's 4 terminals. . . Before I write the rest of a very long reply, please ask me some more questions so that I can focus on what you need to know. Please describe what you are doing.
Apr 29, 2010 | Cooper Lighting Lighted Switch
What sense is there in a three way switch with an off position? yes, if you turn it off the other switch will not work.
If a three way switch is wired correctly you can turn off the light or appliance from either switch as you can also turn it on from either switch. If you have two doors entering into your living room and a three way switch for the main light at each entrance then either switch can turn the light on as you enter or either switch and turn the light off as you exit.
Dec 02, 2009 | Electrical Supplies
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Holmes Products HPF650-U Stand (Pedestal) Fan Logo
64 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
James Coghill
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
