Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
Chnaged the color wheel and lamp. stanby/temp and
I have a Samsung hlp6163wx/xaa changed the color wheel and lamp. stanby/temp and lamp keep blinking nothing happens when i try to turn it on
  • Samsung Master
  • 610 Answers
YOU MAY STILL HAVE A BAD BALLAST OR POWER SUPPLY BOARD.Samsung recommends replacing the ballast and power supply board at the same time.
Posted on Jun 04, 2010
Samsung h1s6187wx wont turn on
Two things to do in order: remove and inspect lamp to see it is not shattered inside-----with it out also inspect the color wheel that faces it to see it is not shattered or missing pieces.
Jun 07, 2012 | Samsung HLS6187WX/XAA
Ml-r4667w timer,power,stanby/high temp leds on front panel blink replaced lamp w/original pt
If you replaced the lamp and it illuminates and three blinking leds still appear the you have a bad Color Wheel.
Apr 07, 2010 | Samsung HL-R4667W Rear Projection...
I have a Samsung TV # HLP6163WX/XAA. A loud humming sound started and the picture went to black and white. The green "Lamp" and red "standby/temp" lights are flashing on front of the tv. Any ideas on the...
I also have a Samsung HLP6163W 61in TV,had the same problem had to replace the color wheel. Went on youtube showed us how to do it our self. Saved a lot of money very easy. Good luck!
Jan 15, 2010 | Samsung HLP6163W 61" Rear Projection...
Samsung HLP6163WX/XAA DLP HDTV - lamp and noise issues
Hello:
Replace the color wheel again, its gone bad again. the clicking is the ballast trying to fire the lamp. The Ballast will not fire the lamp until the color wheel has reported it has reached an RPM of around 9000rpm. This is a normal sound. Most of the time the color wheel will make a loud whining sound when bearings go bad, sounds like a Airplane using reverse thrusters when landing and a even louder sound when it shatters in the housing. Also the reason it may of gone bad so soon is because they make to versions of this color wheel, Bearing type and the Air type. I don't know who installed your color wheel, but it should of came with a small tag or paper of some sort with numbers on it. Most people throw this away when it is very important to let the unit know which type of wheel is being installed to set the parameters for either type of wheel. Most people who install colors wheels themselves to save money do not know this, and the only way to install the new settings is thru the Factory Service Mode. There are also color parameters to input for the type of wheel being used.
This is your basic Color wheel 101..
Hope I gave you some insite of what may of caused your problem...Please leave comment if more info is needed..Lavell
Or email me: Delhielectronics@live.com
Oct 01, 2009 | Samsung HLP6163W 61" Rear Projection...
HLP 4663WX/XAA
sounds like the color wheel has gone out
Dec 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Won't turn on
Make sure that you have the orange flat cable turned the right way when you plugged it in. I accidentally turned one the wrong way and that was the response I got. Hope this is all it was if this does not fix it I would measure the ballast and make sure the 200 or so volts is coming across.
Feb 07, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
672 people viewed this question
Henry  Thomas
Henry Thomas
