Question about Cameras
LOOKING FOR THE MEMORIES CARD FOR THE VIVITAR 2775 CAMERA MEMORY CARD NUMBER 2 MB 3.3
  • 123 Answers
Http://www.flashmemorystore.com/vivitar-vivicam-2775.html
Any of these memory cards will work with your camera.
Good Luck.
Posted on Apr 09, 2008
Out of memory message after 3 photos on new memory card
Hi Bob,
Your camera has two memories. It has a 23 Mb internal memory in addition to the SD add-on memory. If you look on page 30 of the Reference Section of your camera's manual Number of Exposures Remaining table (link below), you will see that when set at the highest resolution, your camera will only allow three exposures in the 23 Mb memory. I would go into your camera's menu and make sure that you have set it to use the SD card instead of the internal memory. You may also want to take lower resolution pictures to increase the number of pictures you can fit in memory. Also, make sure that once you do that, you reformat your SD card in the camera, not on the computer.
http://download3.nikonimglib.com/archive1/nnTgc00N0x4q00P2lCs46LoqNp55/S9500S9400RM_(En)06.pdf
Mar 12, 2014 | Nikon Coolpix S9400
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
Lens cover does not open and camera shuts off it is a vivi 5385 vivitar digital
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 09, 2010 | Vivitar ViviCam 5385 Digital Camera
Brand new vivitar 5018 keeps showing insert memory card but when card inserted it reads card not ready and flashed between 2 screens...please help. I have tried 2 memory cards, one 64MB SD card and one 4GB...
Vivitar cameras are known for there inability to function normaly. Alot of these and many more problems I have encountered are manufacturer problems and can not be fixed on your own. the best thing to do would be to contact Vivitar and see if they can give you a refund or replace it. it is best to call but as I do not know the number here is a link to their website. I hope this helps -Richard www.vivitar.com
Mar 27, 2010 | Vivitar ViviCam 8025 Digital Camera
Upgrade sdram for Vivitar Dig 10x25 Camera Binocular from 16 mb to 32 mb or more
Sorry, the internal memory can not be expanded and there is no slot to add an external memory card .
Mar 21, 2009 | Vivitar MAGNACAM Binocular
I have a question. Can I use a 2GB memory card in my camera?
Any SD card up to 2GB in size should work in this camera.
Nov 29, 2008 | Vivitar ViviCam 3746 Digital Camera
Vivitar Vivicam 3 3 1 5 Digital camera
the reason it turns off in 2-3 seconds is because your not using it during that time and it has very little memory spacing
Aug 19, 2008 | Vivitar ViviCam 3750 Digital Camera
MEMORY CARD
I had the same problem today with a 2 GB card. I think it may be the size of the card. When I put in an old 32 MB card it worked fine.
Dec 26, 2007 | Vivitar ViviCam 3785 Digital Camera
Vivitar vivicam 3713
1. Digital camera? You don't need the company software, download adobe album starter it's free. Picasa from google is also free and does the same job. Both are likely worlds better then the company supplied crap.
2. Your camera takes SD memory cards, buy one online or at a computer/electronics store. It's a lower end camera so it may not support the largest SD card you can buy. I would try a 512 mb but it may support upto 2 GB or as little as 128MB. The card type is SD. Take the camera in and they will help you find one that works.
3. Dunno about that auto delete, go through the menu on the camera itself, is about the best i can suggest.
Nov 09, 2007 | Cameras
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
