Question about Gateway LX6200-01 PC Desktop
Can i take the mother board out and put it in a gaming tower medium size..
  • 29 Answers
You can if the power switch/reset bottun/power led/hdd led are not proprietary and banded together into a single **** plug. and if the mounting holes and setup will accept a gateway motherboard. but the power switch pin setup is what is the deciding factor in this switch. two wires going into a two prong female little black plug. the same for power led, reset switch yada yada. your gaming case is going to have these. if they match, then go for it it will work. oh and be sure to check the distance between the processor heatsync and fan combo to the power supply. some cases bunch them too close together and in some cases they wont fit in the case, i.e. the powersupply being 2 inches into where the cpu cooler unit should be :(
Posted on Jun 04, 2010
Is it possible to upgrade the mother board in this computer?
Dell Cases are very often only for Dell boards--connectors not standard--It can be done,but a lot of trouble. If you want to really speed up look for good complete kit from tigerdirect.com--and put it together--Will work A LOT better than what you can buy at stores.
Jan 31, 2014 | Dell Precision 390 Workstation Tower,...
Hp D 530 - DK907T 902-FAN COMMAND 2 PIN CONNECTOR FROM POWER SUPPLY NOT CONNECTED NB i've changed the chassis it was SFF ans i 've changed in Tower with a standard power supply
Maybe you put the wrong jumper of the power jumper for the front panel.
Explanation:
You can see the switch to turn on the PC right, then make sure that switch correctly installed on the right jumper on the board. Follow the cable to attach to the mother board.
Aug 22, 2011 | HP Compaq Business Desktop d330 Slim Tower
Hi I have a very weird computer problem, basically the computer screen will not start like it used to. When i press the power button everything in the pc turns on it seems but the monitor screen is black....
this a tower or a laptop
tower ...clean all the slots of the mother board
laptop the flexible wiring connections of the mother board to screen is toast
Apr 22, 2017 | LG L226WTY-BF Monitor
Hello, I have a problem with my mobo asus K8N-VM. Not send signal to the monitor. Please give me some advice!
make sure battery is in mother board make sure the fuse is good and in mother board make sure aluminium tower is clamed on black chip to mother board and also make sure fan is cecurelt tight on mother board.
Feb 26, 2011 | ASUS K8N-VM Motherboard
Had to put my motherboard in a new case, and i have tried to follow the manual but i am still lost as the pc is not powering up? i think i have connected everything correctly but still not getting power,...
make sure the aluminum tower is covering black chip on mother tight with metal clasp on alumnium tower is covering chip make sure fan is properly tight on mother board make sure battery in mother board is in and make sure fuse is in mother board then restart push f2 and start your reboot....
Feb 17, 2011 | Foxconn 760GXK8MC-RS Motherboard
Yahoo games
Hi yoyo209:
You may have a failing mother board. This is a common problem with these models...do some search on the web.
Best maybe to replace the mother board with a same size board. You may have to re-install windows over your system to get the drivers and mother board to work right.
Oct 17, 2008 | E-Machines -T1840-CELERON-1.8GHz,40GB...
I have a p4s333 mother board
Hey there
This is the sample picture of the M/B.
I hope this would help you a lot for reference.
Gimme acknowledge by rating me
thanx
Romy
Aug 04, 2008 | ASUS P4S333-VM Motherboard
Gateway 505gr motherboard replacement
not powering up does not mean the mother board is bad , the power supply going bad is more likely to be the problem . But your tower is considered to be a mini tower ive got the same one that I replaced the mother board on . dont mess up and get the wrong size board , it will not fit!
Jul 17, 2008 | Gateway 505GR PC Desktop
HDD Size
This mother board should be able to take any size mother board, please remember to put a good rating on my profile.
Kind regards
Dustin Ellse
Jun 26, 2008 | ASUS CUV-NT (CUVNTWOTVWOV) Motherboard
Gigabyte mother board
hi reason y it wouldn't start is because the 2 is not compatible, what u can do is get a Intel P4 not a celeronD check the socket size and make sure that it correspond with the board that u have. The board that u have uses a 478 socket size so u need to get a processor with the same socket size ok... that should do the trick
Nov 23, 2007 | Intel Celeron D 330 2.66G CPU...
Gateway LX6200-01  PC Desktop Logo
83 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
