Question about Logitech EX100 967499-0403 Keyboard
Space_bar_problem The_Space_bar_came_off.How_do_I_put_ it_back_on_correctly?
  • 493 Answers
I hope this video helps.
Best wishes
Posted on Jun 04, 2010
    Top Expert:
  • Logitech Master
  • 76,682 Answers
They just snap on and off, so if u can't put it back on it is broken.
I have a Smith-Corona Super Correct electric typewriter and the spacebar is stuck on the downward position.
Some of these have a leaf spring that either twist to the side or breaks. Usually there is a spring that pulls that space bar back up.
Sep 24, 2017 | Smith Corona Office Equipment & Supplies
Need to know who to space bar back on
Will the long edge snap into the clips on the base, or the space bar? Place that first. Then aligning the two ends and the post and push down.
Apr 01, 2014 | Computers & Internet
Space bar popped off how do I put it back on?
if nothing is broken, then try to put it back to it's pevious possition, tush gently down, until it clicks....do not use much power...
Mar 27, 2014 | Kensington Computers & Internet
O want to install a new key . What are the steps ,please
A key falling off of a keyboard might be an annoyance, but it is not a reason to buy a new keyboard. Regardless of which key falls off, it can be replaced fairly easily. Although the method of replacing typical letter keys is a little different than replacing the space bar, replacing either of these types of keys can be done in a few minutes.
Carefully pry the key from the keyboard next to the key that has fallen off. This key can easily be pried by sliding a flat-head screwdriver underneath it and popping the key out. Be careful to make sure the key retainer underneath the key stays in place, especially if the key retainer has also fallen off the key you are attempting to fix. Look closely at the key retainer underneath the key that was just removed. Notice there is a notch in each corner of the key designed to hold the key in place. Place the key retainer back into place if it has fallen off the key you are trying to fix. Make sure it is positioned exactly as the key retainer next to it is. Put the key on top of the key retainer. Use your index finger to firmly push straight down on the key to lock the key back into place. Do the same to the key that was taken off to view the other key retainer. b> Replacing the Space Bar b> Turn the space bar upside down and use a flat-head screwdriver to separate the retainer from the back of the space bar key. Place the retainer into its place on the keyboard. The retainer will hook into small hooks on the left and right sides. The small metal bar from the retainer should line the bottom of the area where the space bar will be placed. Put the space bar back into the place where it belongs. Spread the ring finger, middle finger and index finger across the space bar, and push firmly until the key snaps into place. Put the space bar key back in place and gently press on it with fingers until it snaps back in place.
b>
Jan 16, 2013 | Computers & Internet
My Dell Latitude D630 spacebar came off. Nothing looks broken, but I can't get it back on.
If the hinge parts are not broken and are still in place then place the space bar over these parts, align it so it is in the correct position then press the space bar down until the hinges click into the space bar.
Dec 15, 2012 | Dell Latitude D630 Notebook
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
My spacebar key is no longer working properly. I have an acer aspire laptop 5735Z . I deliberately pulled the key off to clean underneath and then just clicked it back on, thinking it would work normally....
There is usually a metal piece under the space bar, if it isn't seated properly the space bar will teeter. Try to remove again and see if they metal bracket is seated correctly.
Oct 18, 2017 | Acer NSK8458AN Keyboard
Where is space bar located on address screen?
The space bar on your unit is on the bottom of the keyboard, next to the "M" key. It looks something like this [, but on it's back. Let me know if this helps.
Jan 04, 2010 | Garmin nuvi 200W GPS Receiver
Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
Dec 28, 2008 | Acer Aspire 1360 Notebook
Voyager space bar freezes when texting
you shouldtake the phone and have it diagnosed to see if the phone needs to service or have the firmware flash or upgrade to correct the freezing issue.
Aug 23, 2008 | LG VOYAGER VX10000 Cellular Phone
Logitech EX100 967499-0403 Keyboard Logo
35 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
