Question about Rohl A3608LMPN Single Lever Country Kitchen Faucet with Metal Lever Handle...
Water leaking from the faucet onto the countertop.
I have a single handle kitchen faucet. Recently I had to repair a drip from the faucet and not long after that water started leaking from the bottom of the faucet onto the countertop. It is a very big leak. I have turned off the water and only use it if I absolutely have to. Can someone please tell me how to fix this?
  • 349 Answers
Http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Posted on Jun 05, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Leaky kitchen faucet
    What kind of faucet? (single handle, double hndle, kitchen, bathroom) Where is it dripping from? (handle, aerator or faucet head, under the sink) There are many types of faucets and many types of leaks. Sorry to be so vague but there's a pretty wide spectrum of possibilities, a little more info will go long way.
    Feb 04, 2013 | Plumbing
    Leaking faucet
    Secure your water
    Determine the cause of the leak
    Change the Seal on that side (Double Handle)
    Change Cartridge on Single Handle
    Nov 20, 2012 | Delta Faucet 2100LF Classic - Double...
    Single handle shower/bath faucet is dripping. Want
    I can fix this.
    What is the last thing you did before this problem started?
    Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
    Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
    ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
    Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
    We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
    Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
    good luck
    Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
    I have a delta single handle kitchen faucet. It has shifted and is not centered. It is hard to move the handle to the left for hot water. How do I center it and tighten it back?
    Loosen the retaining nut holding the faucet to the underside of the countertop/sink. Use a deep socket or basin wrench (http://images.lowes.com/general/b/bwrench.gif)
    Straighten out the faucet and have someone hold it straight
    while you tighten the retaining nut.
    This problem may be a sign that the faucet needs some maintenance. You may want to read this as well:
    http://www.fixya.com/support/t2480325-delta_single_handle_kitchen_faucet_pull
    Aug 28, 2009 | Delta 2402 Classic Single Handle Kitchen...
    Repair leaky handle
    Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
    Apr 21, 2009 | Plumbing
    Replace the seal on the 470 DST single handle pull out faucet
    Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
    Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
    Rohl A3608LMPN Single Lever Country Kitchen Faucet with Metal Lever Handle... Logo
    1,007 people viewed this question
    Top Rohl Plumbing Experts
    Donni Steen
    obsteiner
    john h
    Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
