Question about VillaWare 6150 Mulit Baker Waffle Maker
I ahve a wonderful conditon villaware waffle and panni sandwich maker. It has a knob with numbers 1, 2, 3 and 4. I have no idea how to cook a waffle on it. I am guessing you heat it on maybe 3 until the red light goes out. Does anyone know? No manual was included. I don't care about the panni things that came with it.
  • 268 Answers
You can download the manual from this site:
http://www.retrevo.com/samples/VillaWare-manuals.html
Recipes:
http://www.mrbreakfast.com/article.asp?articleid=29
Bon appetit!
Posted on Jun 04, 2010
Why is my Mickey Mouse Waffle Maker 5555-02 cooking hotter than normal?
The top of your waffle maker has an indicator on the top that shows when the heating coils are on. It should go out when the iron reaches the correct temperature. If it does not go out it may mean that the contacts are stuck and that it is dangerous.
Jul 27, 2014 | VillaWare 5555-01 Mickey Mouse Waffle...
Need manual for villaware uno 2003 uno heart round waffle maker
http://kitchen.manualsonline.com/manuals/mfg/villaware/villaware_waffle_iron_product_list.html
Dec 05, 2013 | VillaWare Kitchen Appliances - Others
Need manual for villaware belgian waffle iorn model 2001
Free Villaware Waffle Iron User Manuals ManualsOnline com
Higher model numbers are often the same as older lower numbers.
Compare your to one of these.
Nov 18, 2013 | VillaWare Kitchen Appliances - Others
Lost instruction manual
Instructions
How to Select a Waffle Iron
Determine what type of cooking you'll be doing. If you're planning on preparing one waffle at a time, for example, then the smallest model of waffle iron will be the best fit for you. On the other hand, if you plan on frequent entertaining, or if you have a larger family, you'll probably want to choose a deluxe model.
Decide on the type of waffle maker that you'd like to own. There are a number of these available, ranging from simple differences---round versus square, for example. Some feature removable cooking elements that can be replaced with others, such as grilled sandwich attachments.
Internationally Accredited Hospital Visit Now to Get a Healthy Life!
www.apollohospdelhi.com
Take the varying grades of quality available in waffle makers into account when choosing one. This point may seem obvious---choose the highest quality waffle iron, right? Not necessarily. If you plan to use your waffle maker on rare occasions, say, once every couple of months, then you won't need the highest quality available. Waffle making several times monthly, however, will warrant a sturdier model with thicker non-stick coating applications applied to the cooking elements.
Consider the cleanup aspects of each waffle iron that you're comparing. Some waffle irons feature removable cooking elements; this is a tremendous benefit when cleanup time comes around, as it is much easier to clean the grill elements separately than attached to the entire waffle iron.
5
Take brand into account when making a decision. Brands with a reputation for high quality are usually more expensive than lesser-known labels. However, this doesn't mean that an "unknown" brand can't produce a good product. When taking this aspect into consideration keep in mind the requirements that you need and purchase a waffle iron accordingly. Additionally, many celebrity chefs have endorsed cooking products---including waffle irons---which adds a little more cost to the product. Finding the company's non-endorsed model of waffle iron will mean the same quality at less cost.
Jan 11, 2013 | Kitchen Appliances - Others
Controls not accurate on uno waffle iron
Thats why they give you the control knobs so you can set it for the best performance. A waffle will change heat requirements depending on ingredients in the waffles and the altitude you live in and the amount of humidity in the air.
Jun 01, 2010 | VillaWare 2005 Uno Petite Waffle Maker
The waffle maker just stopped being hot. Red light was on, but machine was not cooking the waffle
I see this is an old post but I was just looking for parts for mine and saw it. It seems like many have this problem. I think it is a design flaw. I took mine apart and founf the wires at the top heating element melted and shorted. Luckily there is an in line fuse that protected everything. the problem is finding replacement parts. I have just contacted the company about parts. Only the proper parts should be used to fix this. rigging something would be dangerous or worse.
Jul 04, 2009 | VillaWare 2010 Waffle Maker
Turns on but doesn't Cook
It sounds like this is a common poblem but I found what it is. I am a mechanical engineer and fix anything and everything. I had the same thing with my Villeware model 2010. I took it apart and traced with a meter to find the problem. I found the wires to the heating elements in the bottom half melted and shorted where they cross (bad design) just past an inline fuse ( good part of the design!). I can't find any place that carries parts and contacted Villaware direct but do not expect any luck in getting a new wire harness. The fix is either the proper harness or the correct fuse and high temp wire and correct crip connectors. Bypassing the fuse or using incorrect wire would be dangerous, would destroy the control board if another short would occur or possibly lethal from shock or fire.
Feb 23, 2008 | VillaWare 2010 Waffle Maker
VillaWare 6150 Mulit Baker Waffle Maker Logo
189 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
