Question about Frigidaire FAC125 Thru-Wall/Window Air Conditioner
This ia afrigidaire ac window unit, model fac125p1a1.when unit is turned off compresor keeps running.the only way to turned off is by presing the test botton at the end of the power switch;if it is on for awhile ice star to acumulate on the evaporator coil.pls advise.joe
3 Suggested Answers
  • 1894 Answers
SOURCE: Frigidaire AC Window, Model # FAC107P1A2
please leave the unit unplugged from the main power for few hours and check if it works
Posted on Jun 29, 2008
hemantraj
  • 638 Answers
you have clearly mentioned in your question itself that electrical cord does have power going into the unit.i feel it may be the problem with your power cord wire . try replacing the cord first and check whether the power reaches the unit.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
A/C error code F0 Westinghouse
Here is the information i found on error codes i found on your brand. Westinghouse Air Conditioner Error Codes
If you need any more help i would suggest you call your local ac repair company.
AC Repair Fort Lauderdale
Apr 24, 2015 | Heating & Cooling
My air conditiner stop working in 2005 scion xb
Sounds like the clutch on the compresor unit is not working.
When your car is running turn the ac on and check under the hood you should be able to hear a click every few seconds, if you dont then turn off the engine and take the key out.
If it don't click, look for the wire coming from the compresor unit towards the wiring harnes there should be a plug check for corrosion inside the plug.
If it does then go to any auto parts store and locate the ac refill bottles and follow there instructions.
Hope this helped you.
If it does click th
Sep 18, 2012 | Cars & Trucks
Warm air is blowing from the AC
probably need leak fixed in unit or just recharge
Jul 23, 2010 | 2006 Toyota Tundra
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Ruud 10 compressor not working
First make sure there's power to the unit outside , if yes set the theermostat on cold ,auto and to the lowest degrees ,then look the outside unit contactor, it should be pulled in (sometimes it takes to 5 minutes beacause a time delay) , if not the problem is in the thermostat , but if yes and there's power on the other side of the contactor ,either the compresor running capacitor is bad or the compresor itself went bad .Try replacing the capacitor first (the cheaper option) and adding a startting booster in paralel with the capacitor ,if still the compresor doesn't start you nedd to replaced it.All this counting that the fan in the outside unit works ,if doesn't replaced it.
Aug 05, 2009 | Ruud Matching Split Air Conditioner
My york central air condenser keeps running. It cools but, it just keeps running.
Some possible problems..turn thermostat where AC compressor should not run. measure lo voltage to the contactor in the compressor housing. If there is voltage there then thermostat is defective. Remove one lead of lo voltage at contactor. Compresor should stop. If not contacts are stuck. Replace or burnish contacts..
Apr 27, 2009 | Samsung AW0503B Air Conditioner
Gurrgeling noise after compressor kicks in
The sound that you are hearing is the refrigerant moving through the system. That can be a very normal sound. If you are not experiencing any other issues I think it is ok.
I can't believe that just sitting in a box can harm it. If it was stored in an upright condition, you should be fine. The system has oils in the compressor. So if it was stored upside down or something then the compressor could have run dry. This is usually ok if the unit returns to an upright position for a day or so before it is run.
Jul 03, 2008 | Haier hwr10xc6 Air Conditioner
Refrigerator Keeps running
Replacing the thermostat should correct the problem. Be sure to install the thermstat exactly as the one you are removing, assuming it hasn't been changed prior. Hope this helps
Jun 10, 2008 | Beverage-Air Beverage Air KR48-IAS 44.9...
Frigidaire FAC125 Thru-Wall/Window Air Conditioner Logo
43 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
