Question about Sony CDX-602 10-Disc CD Changer
How do u fix the power protect - Sony CDX-602 10-Disc CD Changer
  • 516 Answers
  1. Step 1 Determine the type and voltage of your power supply. The easiest place to locate this is looking on the back of the power supply installed in your computer. There should be a sticker which gives information about the supply. If you don't see it there, then check your computer manual. You should also be able to find it online at your computer manufacturer's website.
  2. Step 2 Purchase the appropriate power supply online or at a nearby computer store.
  3. Step 3 Unplug your computer. Detach any USB-connected devices, printers, monitors, etc.
  4. Step 4 Open the computer case with the screwdriver. Remove the screws and set them aside.
  5. Step 5 Ground yourself by touching a large metal object. This will dissipate static electricity in your body which can damage electronic components.
  6. Step 6 Locate the power supply. It is usually near the rear of the case, where the plug enters the machine.
  7. Step 7 Unplug the power supply from the motherboard and peripherals. The power cables are usually multicolored and fit into the various drives and other internal devices by means of a socket at the end of the power cable. The power cable attached to the motherboard is usually secured with some type of tab that you have to press before pulling on the socket.
  8. Step 8 Unscrew the power supply from the case. Check the back of the case for a series of screws in the vicinity of the power plug and unscrew them. That should release the power supply.
  9. Step 9 Remove the power supply from the case.
  10. Step 10 Insert the new power supply and screw into place.
  11. Step 11 Plug the power supply back into the motherboard. Attach the drives and peripherals.
  12. Step 12 Replace the case cover and screw this back on.
  13. Step 13 Plug in the computer and reattach any external devices (hard drives, printers, etc) and monitors.
  14. Step 14 Start your computer. It should boot into the operating system as normal.
Posted on Jun 04, 2010
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
If wrong ac adaptor is used can this cause protected message, and can it be fixed?
Hard to say, but protected means protected. Minidiscs usually won't accept too much power ... unless you REALLY overdo it.
I have been there and I would think everything is fine. Just try it with the proper power.
Aug 10, 2013 | Audio Players & Recorders
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
Daughter plugged a 12amp vaccuum into protected
replace the part it is not worth cost to fix and not like to perform properly. As you fix on part it ill likely be a cascade effect of repairing more and more as you fix one part and insulation is damaged and will not be safe to provide power protection or back up.
Aug 22, 2009 | Computers & Internet
"protected"
First, disconnect all speaker wires from the unit and power it back up. If it does not go into protect. post a comment and I can walk you thru troubleshooting. If it goes into protect, it needs to be serviced.
Jun 24, 2009 | Sony STR-DE835 Receiver
My Stereo Is Always On Protect Can It Be Easily Fixed
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 27, 2009 | Sony Audio Players & Recorders
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
May 02, 2009 | Sony Audio Players & Recorders
Protect keeps flashing
Apr 23, 2009 | Sony STR-DE475 Receiver
Protect and Push power
A sign flashed across the screen "Protect and "Push power" Please what does this mean? and what do i need to do to fix it?
Regards
Fabio Catarcione
Dec 22, 2006 | Sony DHC-MDX10 Shelf System
Sony CDX-602 10-Disc CD Changer Logo
251 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
