Question about Samsung HLP4663W 46" Rear Projection HDTV
What is an alignment chip on a RPTV and are they expensive
ITS YOUR CONVERGENCE A CONVERGENCE JOB COST ABOUT 300 DOLLARS THE CHIPS ABOUT 130 DOLLARS
Posted on Jun 11, 2010
Picture takes several minutes to appear
Is it RPTV, old set? If so, probably need to just replace the set. Replacement of the projection tubes is very, very expensive; more than the set cost new.
Feb 06, 2015 | Televison & Video
52WM48P Rear projection TV Lamp fitting
Original brand Toshiba lamp ,unit price is USD100
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 13, 2014 | Lapbix Tv Lamp For Toshiba 52wm48p 120...
White spots on screen
There is a good post on this subject at the FixYourDLP's blog... I believe your issue is result of a defect DMD DLP Chip. You can read more about this issue here:
http://www.fixyourdlp.com/2012/08/10/replacing-the-4719-001997-dlp-chip-in-the-mitsubishi-wd-57734-rptv/
Dec 31, 2013 | Mitsubishi WD-60735 Projection Television
Sony rptv STK chip pins making spark and smoking
replace the two convergence ICs and also check the low ohm resistors and pico fuses. You can get the sony convergence repair kit for most sony models from www.tvrepairworld.com which has both ICs 4 of the resistors and all 8 pico fuses plus instructions for doing the repair.
Jun 24, 2012 | Sony Televison & Video
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Jun 04, 2012 | Mitsubishi Televison & Video
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Red band at top of tv
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or that red band you are getting.May the Lord Jesus bless you!
Oct 20, 2009 | Sony Televison & Video
Developing white dots
white Dots appearing on Mitsubishi DLP 1080p. What causes this?
Jul 15, 2009 | Mitsubishi WD-60735 Projection Television
Cannot adjust convergence on Mitsubishi RPTV
as long as there is no bowing in the picture and the color does not want to move then there is probably just a bad resistor on the convergence IC that controls the color alignment , thus the resistors would have to be tested to find the low valued resistor on the IC
Nov 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
