Question about Dell Inspiron 2650 Notebook
When I try to turn the laptop on it says "Operating System Not Found".
  • futzysmurf Jun 04, 2010
    When I turn on my laptop it says "Operating System not found". I was told that the hard disk had become disconnected but that doesn't seem to be the case.
  • 776 Answers
To stsrt with please check boot order in BIOS. Maybe you have all three options to boot from CD/DVD drive. There is an option for "Boot from Network" that's got enabled in the BIOS, that can cause the message if you're not actually booting from a network.
When the system starts, use F1, F2, F10 or a combination like maybe Ctrl/Esc to enter the BIOS
When this instruction shows at startup, press the appropriate key, and you'll be shown a screen or screens of options for how the computer has hardware components set. Depending on how your BIOS screen is laid out, if an option to "Boot from Network" is enabled, it should be turned off, or if "First Boot Device" is set to "Network", it should be changed to a setting like "HDD0", or on a laptop where there can normally only be one hard drive, likely just HDD.
If you find an inappropriate setting like this and change it, save and exit from the BIOS setup, the system will restart and should boot Windows from the hard drive as normal.
Second issue could be an issue with the MBR (Master Boot Record). If your MBR or FAT is bad. (MBR is the Master Boot Record where the HDD stores the initial instructrion for booting, FAT is the Table where all the files are marked).you get this error.
Try this:
http://askbobrankin.com/fix_mbr.html
Posted on Jun 04, 2010
  • Dushyant Bist
    Dushyant Bist Jun 05, 2010
    Please let me know if you need more information.
    Please accept the solution if the information provided has been helpful.
  • Dushyant Bist
    I am the 2nd person to work on your issue, If the solution provided by me has helped please accept the soluion.
  • Dell Master
  • 6,993 Answers
your laptop is showing "Operating System Not Found" because its not seeing your hard disk. You hard disk must have shifted from its normal position, that is, its not well connected to the laptop. This must have occurred when you are moving the laptop about.
To solve this problem, shut down your laptop and remove the battery, then remove the hard disk from your computer and fix it back in and turn your system back on. That's where the problem is coming from.
Not until your system sees the hard disk, it will keep showing "Operating System Not Found" and not boot.
I hope you understand my explanations.
Good luck.
  • 1 more comment
    Where is the hard disk?
    I found the hard disk, took it out and put it back in. It still says "Operating System not found".
  • Walesarumi
    Walesarumi Jun 05, 2010
    whether you agree with me or not, the hard disk is the cause of the problem. Or, it could be that the system is seeing the hard disk but cannot read/see the operating system on the hard disk.
    Restart your computer, press F1, in other to enter bios setup, check if your laptop recognizes your hard disk. If it recognizes it and the problem still persist, then it means you will have to re-run/setup your windows operating system (win xp/vista). But I don't want to believe that the operating system files on your hard disk just disappeared like that.
    In any case, reinstalling your windows operating system (win xp/vista) will/should solve the problem.
    I wish you good luck.
Hello my laptop keeps saying no operating system found
This is a problem with recognizing your hard drive or the Operating System installed on the hard drive. Put your Windows 7 or Vista CD into your drive and restart, booting to the CD drive. Try to repair your startup problems. If this does not work, you may have a hard drive failure.
Feb 10, 2015 | Toshiba Satellite A300-0CF035 Notebook
Operating system not found
hi goodner,
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
Primary Master:
Primary Slave:
Secondary Master:
Secondary Slave:
The Primary master should have a value right next to it. If not, either the hard drive is faulty and needs replacement, cable is loose,
If you have a value to it and stil gets the same error the operating is corrupted and needs to be re-installed.
Jan 29, 2013 | Computers & Internet
When turning on my laptop it says operating system not found what do i do
have you tried re-installing the operating system?if not try it.good luck
Mar 18, 2012 | Gateway 400SD4 Notebook
On my Lenovo ThinkPad Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
May 20, 2010 | IBM ThinkPad R30 2656 Notebook
Sony VGN-TX750P laptop Operating System not found message
try seating the hard drive, the HDD might have been loosened when you changed the part.
Hope it helps!
Feb 14, 2010 | Sony VAIO VGN-A170P Notebook
Operatig system not found"
Try reinstalling the operating system, if fail, try running checkdisk on the HDD. If problem persists, replace the HDD.
Cheers!
Oct 20, 2009 | HP Pavilion dv6000z Notebook
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Mar 15, 2008 | Gateway M305CRV Notebook
Operating system not found? I have got Windows Boot Genius to fix problem safely!
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
Oct 14, 2007 | Fujitsu Siemens LifeBook S-6000 Notebook
Dell Inspiron 2650 Notebook Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
