Question about Samsung LN40B630 40 in. LCD TV
How do i increase the number of hertz that my tv work at?
The television is 120 htz. The screen says it's operating at 60htz. How do i increase the number of hertz that my tv work at?
  • Samsung Master
  • 610 Answers
That is telling you that the broadcast signal is at 60 htz.
Posted on Jun 04, 2010
Is there a broad or chip I have a 60htz tv is there a way to make it 180 to 240 htz
Nope - If you have to have that refresh rate you get a new set that meets your parameters.
Feb 03, 2016 | Televison & Video
Make tv show 120htz not 60htz
Impossible unless you buy a TV that has a refresh rate of 120 hz
Feb 15, 2014 | Sharp Aquos Televison & Video
I have a 60 Inc LCD led 120 hertz . sharp aquos . And I want to know what is the best settings for the picture? I tried adjusting it but it looks like a normal tv want to know the beat settings for picture...
The best way to set up a TV such as yours without a calibration device is to get a high definition picture of someone's face on the screen and adjust the color, brightness and contrast until the face looks as life like as possible.
Feb 16, 2012 | Sharp Televison & Video
I have a heart freedom20 inv. batt. chger that runs at 120 hertz .It does everything (charges switches etc.just fine bu the ac output is at 120 hertz instead of 60.
First check the voltage, if the voltage is good then check the hertz with a different meter because if the hertz went up to 120 everything onboard should have burnt out. The hertz works on the low voltage side of 120vac. before going to a repair shop first check the hertz meter. Good luck.
Jan 25, 2011 | Xantrex Technology Heart Freedom 20 12...
My Nesspresso machine is a U.S. Version machine and uses 120VAC 60 hertz power input, and it is used on a private aircraft using a 120 VAC 60 hertz power converter. When plugged in an turned on the small...
I don't know if you already solved the problem, but did you check what the maximum output power of your aircraft is? The nespresso machine needs about 1250 Watts, which is a lot of power. A vacuum cleaner or microwave use less power than that (maybe between 800 - 1000 Watts). Maybe that difference is the reason. Also, you mentioned that you converted from 220V 50Hz to 120V 60Hz. I think you only converted the voltage, a frequency converter would cost thousands of dollars.
Jan 18, 2011 | Nespresso Citizmilk C120
Had my Tv for a week and connected it to a Thomson sky receiver. Everything worked fine until today. When watching sky progammes the screen continuously flashes every second making viewing impossible. I've...
Make sure both deviced are set for 60 htz, it might be that there is a signal overly if one is set for 50 htz and one for 60 htz double check your screens refresh rate make sure its 60 htz as well. If it flashes once every second while staying on most of the second this could be it. check to also make sure all the cords are correctly positioned and try to keep the cords away from audio equipment stereos/ home audio, this can also cause signal issues.
Nov 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Converter for my sony grand wega 60" to work in the U.K.
The specifications for this set list the power consumption at 250 watts so allow for a little extra and go with a 500 watt converter. Also, make sure the converter will change the UK's 50Hz power to the 60 Hz power required for the set. To be exact, the converter must change the UK's 230 volt 50 hertz power to 120 volts (100 will do) 60 hertz. Do NOT attempt to run the TV on 50 hertz power as it is likely you will damage the set
Nov 29, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hitachi tv
Travel and shipping aside, the only problem you would face is the power. European devices run on 220-240 volts at 50 hertz. By contrast, North America uses 110-120 volts at 60 hertz. Check the rating on the televisions back panel and verify it can work in this voltage range (many can work in both).
Another simple annoyance is that the analog tuner (for cable TV etc) has different frequencies and framerates altogether. While digital video will still work fine, tuning into cable or composite video may or may not work correctly.
Sep 09, 2008 | Hitachi P42H401 42 in. Plasma HDTV
No picture of such
Press reset on the console and down on the remote at the same time
Jul 07, 2008 | Nintendo Wii Console
Samsung LN40B630 40 in. LCD TV Logo
305 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
