My printer will not pickup things on my internet please show me what i am doing wrong .
  • 62 Answers
Is it picking up anything off the computer ?
Posted on Apr 09, 2008
Hullo, my laser jet Pinter does not pick paper. It continuously Shows "printing" on the display screen for 40 seconds but does not pick paper. Even the Printer Self test behaves in a similar way. Please...
Does it make a noise as if its doing anything? Most common thing is the pickup roller has worn out, they're really easy to replace, you can just search google or ebay for - pickup roller and whatever the model number of your printer is to find it
Jan 15, 2014 | HP LaserJet P2055d Printer
My HP laserjet printer is showing Out of paper repeatedly. How to fix it?
the out of paper erro can also be caused by worn pickup rollers. These rollers are used to pickup paper from the paper tray and feed it into the printer. When they get worn down they can't grip the paper to pick it up so the printer thinks the paper tray is empty. The pickup roller runs $3.99 and can be installed by the end user, no service center is needed. The part number is RL1-0266 and looks like this:
We carry them in stock if you would like to order one here:
http://www.ccl-la.com/catalog/product_info.php?products_id=202
I hope this helps, if so please rate my solution.
BuddyMc
Feb 09, 2012 | HP LaserJet 1018 Printer
Paper pickup assmbly not working but traly was worked, in samsung 1640 printr, what can i do.
You said Pickup assembly not working which shows you know about Printers. Remove the Cartridge and clean the Pickup Rubber -with the help of spirit and wait for 2 min and try
Oct 28, 2010 | Samsung ML-2510 Laser Printer
Not printing
Please open the manual feed and try to print using manual feed if you are able to print fine using manual feed that check pickup roller of Tray 2.
First of try to print using Manual feed and let me know if it is printing from Manual feed or not.
Jun 30, 2009 | HP LaserJet P2015 Printer
Im connected to the internet but i cant acess webpages
hello,
It sounds like your dns or host file is damaged. Download and run this program and it should get you going. Winsockxpfix This will rest your dns, host file, renew your ip address. After this repair the best thing to do would be scan your system for spyware since your problem is one of the things spyware can do. IThis should work for you, please rate my solution if it does.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | Acer Computers & Internet
Displayshows wrongcartridge
says wrong cartridge, but i changes them, even looked the cartridgea up on the internet to make sure they were compatiable with my printer, they are and it still says wrong cartridges
Jun 20, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Minolta 2300w
color light has nothing to do with this, first try once more to reinstall drivers, if still shows wrong printer, then you have to upgrade firmware, because if you installed the correct mc2300w drivers and status monitor tell you wrong printer there can be 2 things. firmware is broken or printer/computer usb port is broken. so if you can use another usb port or another computer try it or LPT cable. and as a laast thing update firmware.
May 17, 2008 | Minolta magicolor 2300W Laser Printer
** Paper Pickup
Check the paper pickup tray & roller may be its not working. If possible contact the local vendor for printer servicing.
Mar 09, 2008 | HP LaserJet 3390 All-in-One Multifunction...
Jammed cartridge
I understand that the wrong cartridge stuck in the printer.
Please follow the instructions from the below web document to get the issue resolved.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=c00712226
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should work for you.
Regards,
Lawrence
Dec 09, 2007 | HP Officejet 5610 All-In-One InkJet...
HP LJ p2015dn IP configuration using HP Toolbox FX
Hi Basically I powered up the printer unplugged the network cable. Reconnected and waited 2 min. Pressed green button till first sign of green light flashing. The printer then printed out a printout which shows ip address on first and third page. I then used internet explorer to change printer from DHCP settings to fixed. just type new ip address on internet explorer address line. PC and printer must be on same network.
Nov 20, 2007 | HP LaserJet P2015dn Printer
32 people viewed this question
jasbo
jasbo
