Question about HP DesignJet 750c plus InkJet Printer
Hp 750c plus showing error code System error 010030 00070b10 checked the data ribbon seating good both ends carrage and EC board
SOURCE: out of media Design Jet 750c plus
u could try reloading the paper roll, i have had that prob, and had to reload paper. it always fixede it for me. good luck
Posted on Oct 15, 2008
antiochpc
  • 1314 Answers
SOURCE: error code 070020
From the service manual:
070020
One of the Drop Detection errors has occured - or, during the Drop Detection no drop was detected.
Pen checking is set to OFF.
Corrective actions:
1. Perform the drop detect calibration
2. Troubleshoot the cartridges and the drop detector
3. If required, replace the service station
4. Check the cable assembly and the main PCA.
If you are inclined, I can upload the service manual for you which tells you how to enter the service mode and perform the drop detect calibration. Warning: If this is done incorrectly, it could render your machine useless so if you are not inclined to do so, hire a professional to do it. Otherwise let me know and I will upload the manual for you.
Posted on Feb 18, 2009
  • 141 Answers
SOURCE: error on display
either bad carriage or trailing cable if you've already tried new inks.
Posted on Sep 05, 2008
  • 53 Answers
SOURCE: HP designjet 430, the data and media light come on at power up
The sad part unfortunatly is that the sensor on the carrage is below minimum specification. The only solution is to change the carrage as a unit P/N C4713-60039 and its going to be expensive. Normally the carrage belt would be replaced at the same time.
Dave
Posted on Feb 23, 2009
efs_perpends
  • 1996 Answers
SOURCE: hp 750c plus System error 060309
Please take a look at this link and follow the instructions given there. Also relevant links here and here.
Hope that helps you to sort it out!
Posted on May 22, 2009
I just changed a paper roll in my 750c and now I am getting error 010033 00070ae3. any suggestions? thanks
This error means there is a loss of communication between the main board and carriage. I had this problem, and tried to re-seat the trailing cables. This is the flat ribbon cable that travels with the carriage. Having no luck, I trimmed the end of the trailing cable slightly, which allowed fresh material to make contact when pushed back in. Problem solved.
Jun 29, 2010 | HP DesignJet 750c plus InkJet Printer
DesignJet 750c Plus System Error 040502
The bad news is that this seems to be a fatal error of the main board. The only time I have had a similar error is when the carrage motor shorted out and blew the main board. This probably did not happen in your case but something appears to have taken the board out. The main board is speculation, but I think I am correct, sorry, Dave
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
Hp 750c plus System error 060309
May 22, 2009 | HP DesignJet 750c plus InkJet Printer
My 750C printer tells me to clear the cartridge path, I see no problem. How do I clear error message?
Your carrage belt probably needs replacing. Try and lubricate the shaft slightly with a drop of sewing machine oil. Look around either end of the belt where it goes around the motor on left side and tension pulley on left side, do you see a lot of purpleish bits/dust. If you do then the belt needs replacing.
Dave
May 13, 2009 | HP DesignJet 750c plus InkJet Printer
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
Cartridge path
By it going back and forth means all is ok with the encoder strip. Sounds like its asking for a bit of lubrication. There is a special oil available from HP for the carrage. This also works for tha large format machines using plastic bushes such as 500, 800, T610, new 510 etc.
Nov 10, 2008 | HP DesignJet 750c plus InkJet Printer
Out of media Design Jet 750c plus
Oct 14, 2008 | HP DesignJet 750c plus InkJet Printer
Hp 750c error code 070000 00000004
replace carrage pcb then your problem will be solved
Jul 22, 2008 | HP Office Equipment & Supplies
Error on display
Jan 16, 2008 | HP DesignJet 750c plus InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
824 people viewed this question
Seeker5211
Seeker5211
