How to fix error 5700 for canon mp780 printer
  • 19,396 Answers
Hi.
Error 5700 means paper feed position sensor error (ASF-cam sensor error). This error often happens in consequence of a paper jam, as the sensor can get jammed or damaged.
Try resetting the printer by disconnecting the power cord for five minutes. While the printer is disconnected inspect the printer for fragments of paper.Check paper feeder, inspect tabs, remove and put back cassette.
If the error does not clear, then the printer must be taken apart to inspect the ASF section of the Main Unit for an eventual gap between the white plastic guide and the Chassis, that is usually the cause for 5700 error.
Here the troubleshooting for cam sensor error, it is the same as troubleshooting for error 5700.
Posted on Jun 04, 2010
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Feb 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a Canon Pixma MP780, keep getting "clear ADF" messages. changed the settings to off. Also, scanner is giving me some error messages #2, #178
Try Canon support. Type your query. Click "Search"
Example: Type "clear ADF" (You may have paper or some obstruction in the Auto Document Feeder).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444#SupportDetailAct
Nov 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error code 5700.. already checked for jams, none, unpluging won't do it... none of the buttons respond... what else ??
Error 5700 is ASF sensor error.Check first the sheet feeder.If not have a jams the problem is in purge station.You can't fix it by yourself and your printer need repair.
Nov 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 5200 and error 5700
hi there
error 5700 is for your asf senser error clean or changing will fix this error.
error 5200 is for printer head temprature rissing high it may be by printer head or logic card.
Aug 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Jun 08, 2009 | Canon MP520 All-In-One InkJet Photo...
It never works cuz the screen says error 5700 and wont do anything
Error 5700 is usually a paper "feed" jam.Check the automatic paper feed area to see if any paper is jammed
May 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
When i turn it(canon MP780)on, i see a error (##357). How can i fix it?
The service manual says this for ##357:
ASF paper feed (AP) position error.
AND ALSO:
##357 ASF paper feed (AP) position error
Cause: An error occurs at the AP positioning in the ASF (Auto Sheet Feeder) unit.
Solution: (1) To reboot, press [OK] button or turn off and then on the power.
(2) Replace the SHEET FEED ***’Y.
(3) Replace the SPCNT board.
Apr 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Makes a loud popping noise and won't print
http://damnprinter.com/226/canon-service-call-errors.html this site will tell you a couple things you need to know it says a sensor error
Nov 10, 2008 | Office Equipment & Supplies
CANON IMAGECLASS M7 5700 SERIES
first thing is to go to www.canon.com and find your local support links, and download the fresh set of printer management software or drivers.
got backup for your computer?
Feb 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Unable to Print
Maybe if you rubbed some cheese on the front, that would work? Hope this helps.
Apr 24, 2007 | Canon PIXMA MP780 All-In-One InkJet...
386 people viewed this question
k24674
