Question about Schwinn Hitchhiker Bicycle Trailer Tandem Bike
Were do i get a spare hitch for the hitchiker tag along
Does anyone have a clue whether or not a 1965 12x65 capella mobile home has vin numbers or serial numbers? I have looked everywhere and can't find it! I have to have a vin number to register it and...
Jessica, all camper trailers build in North America must have a vin number ,is it possible it was removed ?,if it was a painted over , a little sand paper goes a long way ? look around the frame toward front near hitch check top ,sides and along where tow hitch meets the main frame on left and right , is there ant type of manufacters ID tag inside or out ? , can you do a title search with previous owners in formation ,or ask DMV how to go about it . im really sorry I cant be of more help ,hope this gave you something to go on .
Woody
Aug 28, 2014 | Cars & Trucks
How do i find interior color code
Allure: #4 in the glove box
Century:#1 Trunk deck lid
Enclave:
#4 glove box
Lacrosse:
#4 glove box
Lesabre:
#3 spare tire cover Should be white paper with the information on it or Google it and as for interior codes for lesaber
Lucerne:
#3 spare tire cover or spare tire wheel well
Park Avenue:
#3 spare tire cover
Rainier:
#4 in the glove box
Regal:
#1 Trunk deck lid
Rendezvous:
#4 glove box or #5 left rear storage compartment inside door
Rivera:
#2 Right wheel house or #3 spare tire cover
Skylark:
#3 Spare Tire Cover
Terraza:
#4 glove box
- See more at: http://www.automotivetouchup.com/paint-codes/buick.htm#sthash.6tFH4SbN.dpuf
Jun 27, 2014 | 2001 Buick LeSabre
Can 2003 be equiped with towing trailer package
you can add a receiver hitch made for that vehicle. for light towing you should be fine. it won't handle a car trailer or Large boat.
Apr 26, 2014 | 2003 Hyundai Santa Fe
What is the purpose of a front mount hitch?
Front mount receiver hitches provide a convenient mount for hitch accessories such as a step pad, license plate holder, spare tire mount, or a winch mount plate. It also provides an easy way to maneuver your boat at the launch or campground. B&W Trailer hitches provide all the different hitches available.
Mar 25, 2013 | Cars & Trucks
I want to put a 2" slide-in hitch on my 1991
Go to your nearest UHAUL center and give them your vehicle information. They should pull out part # 75038. It is a Class III with a 5000lbs towing capacity (8000lbs if you have weight distributers installed) The pre drilled holes on the hitch should match the holes on your truck without removing bumper or spare. ( you might have to temporaly remove/ lower them to install the hitch, but you can put it back on without any modifications) Luck!
Nov 01, 2010 | 1991 Ford F150
Spare tire mount on 1986 Sieraa Classic
I had a similar problem with an 88 F250. Measure the tire height with tire standing, then measure space between hitch and measure frame from same place.
If the space between the frame would allow the tire to fit without the hitch, you need a wider hitch. If your current hitch has room for the tire you are all set.
Usually a heavier class hitch will have wider mounting points, but be aware that access to put in bolts may require you to weld the hitch to the truck.
Jul 17, 2009 | 1989 GMC Sierra
Hitch mounted bike rack that doesn't seem to fit Envoy
there are draw bar extensions you can buy that will extend the rack beyond the tire. check with your local trailer parts store.
Jun 24, 2009 | GMC Envoy Cars & Trucks
Trailer Hitch Wiring
If the spare tire is under the back of the vehicle, look on top of it.
Jul 05, 2008 | 2005 Chevrolet Uplander
Schwinn Hitchhiker Bicycle Trailer Tandem Bike Logo
526 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
