Question about GE WSM2700D Top Load Stacked Washer / Dryer
How do i get off the top to the agitator on ge model wwp1180g
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To remove the top use a pry tool or a putty knife and insert it straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Open the screws under them. There is lid switch connector under the console. Unplug the switch from the connector. Now you can access the lid clips. To remove the agitator you’ll need to remove the bolt and lift it with both hands from the underneath. If it is stuck and can not removed easily then apply some WD40 and let it sit overnight before trying to pull it out. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 12, 2010
How to remove agitator
That is a very old GE model. There may be a screw under the agitator cap which needs to be pried off. Even with the screw removed the agitator usually rusts or bonds to the transmission top. GE had a special pulling tool that was a metal ring that fit over the agitator with 3 set screws in it that you had to screw into the outer plastic of the agitator. A gear puller was then needed to pull the agitator off. Don't know if its worth it considering the age of the machine.
Apr 14, 2016 | GE WBSR3140DW Top Load Washer
GE washer agitation starts normal the progressively slows and then stops agitation. All other modes work fine. Model # unknown. Motor or transmission? Thanx people!!!
Model # located on the back of the control box of top load, just inside of door on front load. Other Op modes ok, problem points to agitator support shaft or the belt drive of the agitator.
Nov 17, 2015 | GE Washing Machines
Model wwp1180g
Look at it carefully to see whats in the way of the belt removal. If its still on the unit best to take some pics of it so you have a reference to make sure everything goes back where it should.
Aug 20, 2014 | GE Spacemaker Washer and Dryer Electric...
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    Ge top load washer won't agitate or spin after
    what is your model number is then we can started then okay
    Sep 15, 2011 | GE Washing Machines
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
    Tell me more Is there voltage to motor? The transmission makes it agitate .
    May 28, 2009 | GE WBSR3140DW Top Load Washer
    GE top loader not agitating
    Your agitator splines are probably stripped out.
    Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
    Mar 04, 2009 | GE WBSR3140DW Top Load Washer
    The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
    Dec 03, 2008 | GE WBSR3140DW Top Load Washer
    Ge elite 110 23012 100 top load washer
    look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
    Aug 08, 2017 | GE Washing Machines
    GE WSM2700D Top Load Stacked Washer / Dryer Logo
    Top GE Washing Machines Experts
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
