Question about Haier ESD402 Stainless Steel 24 in Builtin Dishwasher
Control panel shorted
It seems water got in the control panel, and shorted it out , is there a reset ? or can I replace it ?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the control panel has shorted it cannot be reset and it is better to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 04, 2010
Maytag Microwave over the counter -error code SE
Banging on the control panel got it working would indicate a bad connection inside, not a short. Could be anything from a bad wire connection to a cracked solder joint on the main board.
Aug 23, 2017 | Microwave Ovens
I have a kenmore 665-15684. I have clear standing water in the dishwasher and doesn't seem to drain. No lights are on (or blinking) on the control panel and none of the buttons seem to work on the...
It is very likely the computer has failed.
Try to empty the dishwasher with a small container and try it on a short cycle to see if it starts the cycle.
If there is no action then it is time to decide if you want to replace the computer. See item 6 in this diagram.
Hope this helps.
May 16, 2011 | Kenmore Dishwashers
Have american style fridge freezer, model S25B RSB31. Seems to be tripping the electricity supply. When power restored, find that the freezer has two bars where you would see -18c. After putting in and...
Your defrost heat element is shorting, resetting will make it work till defrost cycle kicks in and HEY PRESTO""shorts again...very common fault and bugs the hell out of all of us, check it and I am pretty sure that is the fault. Or you are getting water or condensation in the control panel but very rare.
Regards and hope that sorts the issue...Please dont forget to Vote, I do this for free, Russ
Mar 28, 2011 | Whirlpool Freezers
How to reset control panel on model 587.1517 kenmore dish washer
From what I have read elsewhere, the interrupt *may* have something to do with a thermostat circuit cutting out if the entry hot water is too high ( more than 145F) - it seems like a buggy safety feature i.e. the circuit board thinks that the water heater is overheating. The makers have apparently made changes to the control board to fix this bug but it costs serious $$$ to get a repairman in and buy the new board.
I prefer to use the reset code, and keep my water temp lower when using it.
Feb 20, 2011 | Kenmore Dishwashers
Control panel on gw395leps00 will show power failure
not sure if you need to replace your control panel, but if you do, you'll need this part http://www.repairclinic.com/SSPartOnly.aspx?PPStack=0&pop=1&ShHd=0&ShFt=0&PartID=1257027
your original "membrane switch" seems to have been replaced with this new (improved?) style. it fits your range and will presumably solve any short circuit problems you may be having with your original touchpad/membrane switch
Oct 01, 2009 | Whirlpool GY396 Electric Kitchen Range
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Haier ESD402 Stainless Steel 24 in Builtin Dishwasher Logo
189 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
