Question about Husqvarna Garden
Repair stihl FS 74 carburetor
Need to remove and rebuild a stihl FS 74 carb
4 Suggested Answers
Dolfoff
  • 148 Answers
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Posted on Sep 26, 2009
rwvanlue
  • 486 Answers
SOURCE: how do i set the carburetor on a Stihl FS-55
Over the past 8 years, the FS55 has had at least 5 different carburetors, and they have at least 3 different systems with different adjustments. Many of them do not have much of an adjustment and will not cure running problems. If you are experiencing poor running conditions, I would suggest some basic checks first. The spark arrestor screen is a big culprit on this model.
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 23, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
I am rebuilding a Stihl trimmer model FS 110 R carburetor and I need to know what gaskets to use and where they go
You will need to remove the carb and see who made it as most manufacturer buy there carbs. , ie: walboro, it will have a marking on it along with the carb number such as wt784. Then you can go to ebay or your local lawn mower shop and they should have the rebuild kit. It cost about 4 to 6 dollars. Just reassemble it the same as you take it apart. When you take the jets out be sure to count the turns and then you can put them back when you are done. In addition if you look real close, because the stamp are tiny you will see a L for low idle and H for high speed. Hope this helps.
Jun 04, 2017 | Stihl Garden
I have a Stihl Weed eater will a FS 45 carburetor fit on an FS 90
NO. The FS90 is a 4mix engine and the carb has a (sump) on it which has a pulse pipe going to the bottom of the crank. The FS45 is a totally different carb configuration, and doesn't have the sump. FS90 carb is an C1Q-131A
The FS45 has several carbs that fit:-
C1Q-S97
C1Q-S71
C1Q-S66
C1Q-S58
C1Q-S44A
C1Q-S53A
Apr 13, 2016 | Stihl Garden
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
My Stihl FS85 runs good for about 20 seconds and then shuts completely off. I have replaced the Plug, cleaned out the fuel system and it still does the same thing. Could it be the coil?
Sounds like the main jet or the diaphrams in the carburetor are deteriorated. Remove carb and soak in a good carburetor dip style cleaner and rebuild with a new kit. Also replace the fuel line and filter and use a fresh gas mix.
Sep 17, 2012 | Stihl FS 85 Weed Eater
ZAMA CARBURETOR REBUILD
Unless you really know what you're doing i wouldn't advice it be carried out by a novice. Carbs contain small one way valves that can get damaged. Avoid using airlines to clean and blow out carbs as these can damage the valves. Diaohrams, gaskets and needles are pretty straight forward tho.
Jun 14, 2012 | Stihl Trimmer Zama Carburetor...
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
Sep 06, 2010 | Oregon Scientific Complete Carburetor for...
Need repair Manuel for Stihl br-550 blower
A shop like www.arcolawn.com can get you Stihl tools and parts.
It sounds like your carburetor is not meetering the fuel properly. A rebuild may work but the carburetors on many machines have fropped in half in the past 2 years.
You may have a bad seal on the crank shaft or an air leak somewhere. If you take it to a dealer most shops charge less than an hour time to perform a full check on the machine and you can do the work.
Good luck
May 30, 2010 | Oregon Scientific Complete Carburetor for...
I need to rebuild the carburetor on a Stihl Model 025 chainsaw. An exploded view diagram would help.
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
May 19, 2010 | Garden
Instruction on how to rebuild Stihl FS85 carburetor
The FS 85 was produced in HUGE quantities over a number of years. Several different carbs were used during production and Stihl has several proprietary carbs in use. You will need a Rebuild Kit (NOT just a Diaphragm Kit) for this particular carb. On the carb body you should see a Series and a Model identification.
Example: If this is a ZAMA carburetor, the C1U-S66 might have been used on your trimmer.
Get that info off the carb body and ...
For ZAMA carb lookups click HERE.
For WALBRO carbs click HERE.
Hope this helps.
Oct 04, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
654 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
