Question about Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential
Scooter stops short without warning - Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential
  • Neil Wood Jun 05, 2010
    Hi. Could you please give us a bit more info please? When it stops, does it have any flashing LED's or beeps? Does the battery gauge still show full charge? How do you get it to move again? Neil.
    Problem Solver:
  • 17 Answers
This could be caused by a couple of different issues. If your batteries fall to below 17 volts the unit will shut down. After it sets for a few minutes it may run again for a short time. If this is the case, then the batteries are not being charged properly or they are not holding charge.
Another cause could be the break switch circuit is opening. If that is the case, replace the brake/motor harness
Posted on Jun 06, 2010
Strider maxi charger flashes continuous while plugged in , the 3 diagram lights
Hi have u tested you're batteries u can buy a BATTERY LOAD TESTER ON E/BAY. OPROX PRICE $35. THIS WILL GIVE U an accurate reading on there condition .....Cheers
Jun 16, 2016 | Electric Strider Maxi 4 Wheel Mobility...
How do I check the battery charger to see if it is functioning properly
Some chargers need to be connected to the batteries before they turn on the charge current. With the charger connected and switched on, check the voltage across the batteries and should be about 26 volts for a 24 volt system. And you can use an amp clamp meter for current flow.
WARNING
DO NOT SHORT PINS TOGETHER
Mar 26, 2015 | Health & Beauty
Scooter shorts out while runing
possible throttle pot failure.
Aug 23, 2014 | Health & Beauty
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
Brakes without warning 7 blinks error code
hi Throttle pot issue.... check wiring otherwise replace the pot ...
Regards
Rob
www.gewizrepairs.co.uk
Jun 20, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
Green light flashes when i stop for a few minutes
Hi, okay but does the scooter still run okay ? if so, it maybe warning you that the batteries are getting low, sometimes the voltage detection circuit can get sensitive or simply faulty.
Regards
Rob
Dec 31, 2013 | Lynx L-4 Motorized Scooter
Problem starting scooter when cold.
You need to check that your automatic enricher (often called an auto-choke) is working. You should find then when the engine is cold, the scooter hasn't ran for at least an hour, the enricher will be short. Take it out of the carb and measure the plunger. Put it back into the carb. Then start the scooter and let it run for 5 minutes. Quickly remove the enricher, being careful around anything hot, and measure the plunger again. If there is no change, it's not working. The attached link may help you to understand what I'm talking about better.
Automatic Enricher Operation 10x Speed Choke Bypass Bystarter
You should also check the condition of your spark plug. If it's fouled, damaged, or gapped wrong it could be making starting more difficult.
A battery in poor condition will also make it harder to start. Battery checks link below.
Scooter Battery Checks
Good luck with it.
Dec 29, 2013 | Motorcycles
My legend scooter got left out in the rain an now nothing works I put the batteries in another scooter I have an they work . What could be the problem
Hi themorrows,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. Very difficult to determine exactly the problem without running a diognostic.However, my experience indicates several areas of concern.
1. The faceplate on the tiller has a databoard where everything from the controller in the back plugs into. If that got wet it will short out and nothing will work.
2. If the controller in the back near the transaxle gets wet it to will stop the scooter from starting. Anytime water gets near electronics the water will follow the wires directly into the works and shorts out anything in it's path. Either way it doesn't look good. You need to take it to you closest Durable Medical Equipment Company for analysis.
Good Luck
Tim
May 02, 2011 | Health & Beauty
When I stop the scooter after travelling a short
Hi. Yes, most, but not all machines have a "sleep" mode. More for safety than any other reason. Neil .
Oct 31, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Open Questions:
See all Invacare Supply Group Invacare Scooter Lynx L-3 Questions
Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential Logo
274 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
