Question about Refrigerators
Model FRT16CRH stopped working. I have checked the circuit it is plugged into, and it is OK. Is there a reset button?
  • sdimon Jan 13, 2009
    The lights come on & the microwave works, but the unit stopped cooling.
    Genius:
  • 1,073 Answers
No breaker, could be any of the electrical components
Posted on Apr 10, 2008
How to reset brandt washing machine
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Aug 14, 2016 | Brandt Washing Machines
Why does freezer keep cold and not bottom on a frt16crh
Maybe too much food jammed in to allow cold air to get to the bottom.
Oct 04, 2014 | Refrigerators
Printer error fuser temp
You can find answers to Xerox questions at www.xerox.com/support
Solutions for : Printer Error Fuser Temp Message There are two configuration options available for this model; the Phaser 3100MFP/X and the Phaser 3100MFP/S. Fax features are only available on the Phaser 3100MFP/X. To determine the configuration of your machine, print a Configuration Page. See the Related Items below for additional information.
Solutions ranked by relevance:
  1. Make Sure the Power Cord is Securely Connected to the Machine and the Electrical Outlet
  2. Make Sure the Machine is Plugged Into a Functional and Stable Power Outlet Test the power outlet that the machine is plugged in to by connecting another device to the outlet. Make sure the outlet is functional and stable. If possible, have the line tested by an electrician. If necessary, plug the machine into another power outlet.
    NOTE: The machine should be plugged directly into the wall outlet, and should not be connected to an extension cord, power strip, or Uninterruptible Power Supply (UPS).
  3. Reset the Fuser Error Solution : Reset the Fuser Error CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
    If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times.
    NOTE: This procedure will delete all pending jobs that have been sent to the machine.
    To reset the Fuser error:
    (Click on one of the following links to jump to the corresponding section.)
    To reset the Fuser error for the Phaser 3100MFP / X
    1. Press the [Down] arrow (Menu) button on the Control Panel.
    2. Press the asterisk [*] button.
    3. Press the pound [#] button.
    4. Press the [OK] button.
    5. Press the [1] button. ("00100001" changes to "10100001" at SOS1)
    6. Press the [OK] button.
    7. Press the [Stop] button.
    8. Press the [Down] arrow (Menu) button.
    9. Press the pound [#] button.
    10. Press the [T] button on the keyboard. (Do not use the numeric keypad.)
    11. Press the [OK] button.
    12. Power the machine off, and then power the machine on.
    13. Press the [Down] arrow (Menu) button.
    14. Press the asterisk [*] button.
    15. Press the pound [#] button.
    16. Press the [OK] button.
    17. Press the zero [0] button. ("10100001" changes back to "00100001" at SOS1)
    18. Press the [OK] button.
    19. Press the [Stop] button.
    20. Make a copy to check machine operation.
    To reset the Fuser error for the Phaser 3100MFP / S
    10. Press the [Down] arrow (Menu) button until "T>>Printer" is selected.
Nov 27, 2013 | Xerox Phaser 3100MFP/S Laser Printer
Just got the refrigerator and set it up. The lights won't work.
Check if power is coming to the socket, if yes check plug fuse, if ok check if reset button on circuit board has tripped, try after resetting
Oct 17, 2013 | GE GSS22JFMWW Side by Side Refrigerator
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
Not working at all as if no power to it. I
No reset button. You might tray a hard reset by unplugging it for a couple of minutes then plugging it back in.
If you need more help, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your specific symptoms.
Nov 23, 2009 | Maytag Appliances Over-the-Range Microwave...
Error E42
Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Or try:----------------
TRY THIS STEPS... Reset Counter Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Aug 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Fedders window model A6Y12F2B "New Unit",,only 10 days in use! Just stopped working No Power To Master Panel Air Conditioner Not Working Fuse Panel/Breaker ok,Outlet ok,,power to plug...
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Jun 22, 2008 | Fedders Heating & Cooling
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
