Question about Panasonic PanaFax UF-490 All-In-One Laser Printer
How do i reset the drum counter on a panasonic uf4000 fax machine
4 Suggested Answers
tech435
  • 284 Answers
SOURCE: reset drum
im sorry to tell you this machine does not have a drum counter reset. its a fuse the blows when a new one is in
Posted on Jan 07, 2009
HobbesVT
  • 3 Answers
SOURCE: drum reset for Panasonic kx-mb781
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Posted on May 03, 2009
  • 3 Answers
SOURCE: Machine will not reset drum count
In the copier mode go into f7 mode and reset the drum or process unit count this should clear it
Posted on Jun 23, 2009
Drum life warning on toshiba dp120f
reset drum Counter for DP120
Turn fax off. Hold down 0, 1, 3 on numeric key pad and turn fax on. Then release the 0, 1 & 3 and enter the number 80, wait a few seconds and should see a message confirming counter has been cleared. Then turn fax off and on again
Jun 21, 2012 | Toshiba e-Studio DP170F Plain Paper Laser...
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Dec 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
May 07, 2009 | Panasonic DP-150FX Laser Printer
How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
Panasonic UF4000
Someone is sending you blanks.
Jul 31, 2008 | Panasonic Office Equipment & Supplies
"CHANGE DRUM SOON"
To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
May 30, 2008 | Brother IntelliFAX 2800 Laser Fax
DRUM REPLACEMENT CODE
How to Reset the “Replace Drum Cartridge Soon” Message on a Panasonic KX-FL511
[Menu]
[9000]
[*] (Will display P-SF)
[6722]
[Fax Start]
[Menu]
Nov 18, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic PanaFax UF-490 All-In-One Laser Printer Logo
395 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
