Question about Anthology Solutions Yellow Machine P400T (250006001) 400 GB Network Hard Drive
I'm looking for software for my yellow machine p400t
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
I have the last update disk 3.3 and would be happy to upload it to a file sharing site for you.
Posted on Jul 25, 2010
  • 1 more comment
  • Thomas Irwin Mar 23, 2012
    I just found one of these Yellow Machine units on a back shelf in my shop and it has the ver.2.93 CD. I don't recall why I never used it. Now the CD doesn't read on my PC CD drive. Don't know if the disk is bad. but I would like to have the latest software available in any case so if the offer is still good I would like a copy.
    Thanks, Thom Irwin - amalcrit@znet.com
  • Clayton
    Clayton Sep 19, 2014
    do you still have the latest version that you could send me. Thanks
  • Michael Wright
    Michael Wright Jun 04, 2017
    I am looking for the software if someone has it. Thanks in advace
3 Suggested Answers
peterbest
  • 196 Answers
SOURCE: Unable to acces yellow machine p400t
Set your PC networking to Obtain IP Automatically and see how you go
Posted on Feb 17, 2010
  • 478 Answers
SOURCE: yellow machine server.
Is it just the fault led, let the machine run for a while and see if it starts rebuilding the drives, if it is NEW and you have just installed the drives and never installed the software then you will get a fault I have the q400t which is the platnum version tho they still call it the p400t if you have just received the server then what u must do is power off the server plug in the netcable into one of the 8 lan ports run the install till it tell's you to turn it on then hit next then follow the instructions to setup the server
Posted on Apr 28, 2010
Yellow machine power out won't restart
You will have to get a disk recovery specialist to retrieve your data. The internal YellowBox system is Linux. The specialist will remove the disks and attach them to translation and recovery technology. It will cost money.
Dec 19, 2013 | Anthology Solutions Yellow Machine P400T...
I lost the driver disc , did you know where can I ...
I have the last update disk and would be happy to upload it to a file sharing site for you.
May 20, 2010 | Anthology Solutions Yellow Machine P400T...
Step by step instructions to setting up a yellow machine P400t
Documentation is available at: http://www.yellowmachinesupport.com/
You configure it through the web GUI.
David
Apr 18, 2010 | Anthology Solutions Yellow Machine P400...
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
Nov 26, 2009 | Anthology Solutions Yellow Machine P400T...
Yellow machine server.
Dec 30, 2008 | Anthology Solutions Yellow Machine P400T...
How do I set up the P400T Platinum to be used as a Domain Server?
You can configure it through the web GUI.
The unofficial support website is: http://www.yellowmachinesupport.com/
The manual there will give you the info. I'm not sure it will do ddns.
Good luck,
David
Mar 25, 2008 | Anthology Solutions Yellow Machine P400...
Hello!
I saw on ebay they had some Brand New Diskless versions and One Used Working one. I know it is not a fix but a lot cheaper than the $1200-$1500 they used to be.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=p400t&category0=
Nov 05, 2007 | Anthology Solutions Yellow Machine P400...
Shows drive is full but there is almost nothing on it
Ths is possibly caused by a FAT / TOC error and it may be possible to resolve this using a chkdisk or perhaps scandisk or whatever management tools come with this item.
Jul 18, 2007 | Anthology Solutions Yellow Machine P400T...
Anthology Solutions Yellow Machine  P400T (250006001) 400 GB Network Hard Drive Logo
546 people viewed this question
Top Anthology Solutions Computers & Internet Experts
David Payne
David Payne
Are you an Anthology Solutions Computer and Internet Expert? Answer questions, earn points and help others
