Question about Lexmark X7350 All-In-One Printer
My scanning keeps saying. an error occor while setting printer properties. If another program is scanning please wait for it to be complete and try again
  • Lexmark Master
  • 19,396 Answers
Hi.
If you try to operate the scanner or the printer while a scan is in progress, then this error is normal. The error also occurs when you try using two different applications to operate the scanner.
If no software is accessing the scanner, and the scanner is not busy, reinstall the printer software.
The software can be installed using the CD provided with the printer or downloading a driver online (see:How to install a Lexmark printer).
Before reinstalling software also test using a different USB cable, sometimes a defective USB cable can give you communication errors of this kind.
Posted on Jun 04, 2010
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Nov 19, 2014 | Office Equipment & Supplies
When I try to scan things to email it suddenly has started saying 'send error'. How do I fix this?
reconnect the printer to the internet!- some of yoiour setting have been lost or removed , run the installation program again.I.e. Completely Uninstall the printer from network then reinstall. making sure all settings are completed ( things like IP addresses, Gateway addresses,etc')
Oct 11, 2013 | Kyocera FS-C2126MFP Printer
I installed the Vista Drivers for my HP 4070 scanner and it gives me an error that "An Error Occured while Setting Scanner Properties. If another program is scanning, please wait for it to complete...
Install the latest drivers from the website. To download:
1 Go to hp.com 2 Click on Support and Drives 3 Enter your product name or number, in this case just type in Officejet 8500 All-In-One 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
But before Installing the Software, use the Disc that came with the printer so you can do an L3_Uninstall first.
To go for an L3_Uninstall:
1 Go to My Computer (XP), Computer (Vista and Win7) 2 Right Click on the Driver CD, The one that has the HP Logo 3 Open Util 4 Open CCC 5 Double Click on the icon that says Uninstall_L3
The Uninstall will prompt you to restart the computer once it's done. After doing so, Install the newly downloaded software.
Try scanning again, I hope this worked. :)
Feb 03, 2011 | HP Scanjet 4070 Flatbed Scanner
I have just bought a HP Photosmart plus B210 printer. I have installed it ok and it is wireless connected. everything seems ok for printing but when I try to scan to Paint shop Pro 7 or from Word 2003 it...
Hello Carol,
The first thing you want to do is check to make sure the scanner driver is installed properly and working.
If you are running Windows XP or Vista; go to Start Menu \ Control Panel \ Scanners and Cameras
NOTE: For Vista user you must select "classic view" in control panel to see scanners an cameras.
For Windows 7; go to your Start Menu, in the "search programs and files" section (found below "all programs") type in "scan". You will see a result for View Scanners and Cameras.
Now you should see the HP scanner here. If it is not here then you need to reinstall because the scanner was not installed properly. If the scanner is here, right click on it and select Properties. (For Windows 7 you do not have to right click, you will see Properties at the bottom of the window).
In the properties select "test scanner". If this test fails, the driver is not working and you should uninstall and reinstall the HP.
If this test works then the driver is properly installed. HP should have provided you with some sort of scanning software, try scanning using that. You can also try scanning using Windows Fax and scan (for windows 7), Windows Photo Gallery (Windows Vista) or the Windows Scan wizard (Windows XP).
Thanks,
Pat
Nov 07, 2010 | Office Equipment & Supplies
Flashing message says: Cartridge error: consult user manual.Error 1203. Power on and off works. Otherwise will not change from that message. Trying to send fax. Will not let me copy, scan,...
A "No communication" dialog appears when you try to print or scan.
What to do
If you are printing wirelessly, launch the printer's Wireless Setup Utility and follow the instructions.
If you are connected by USB or ethernet, try one or more of the following:
  • - Ensure the cable is secure at both ends.
  • - Disconnect the printer power suppy from the wall outlet, wait 10 seconds, and then reconnect it.
  • - Restart the computer.
  • - Make sure the correct port is selected in the Properties screen. To do this:
      1. Go to Start, Settings, Control Panel.
      2. Double-click on the Printers folder.
      3. Right-click on the printer icon and select Properties.
      4. In the Properties screen, click the Port tab.
      5. Ensure that the printer port is set to one of the USB port options; see below.
        Click here to view an enlarged version of this image.
      6. Select the port and click OK.
      7. You may need to reboot the PC for the change to take effect.
NOTE: The printer icon may not be displaying in the notification area (the "systray"). Once the port is correctly selected, the icon should appear there.
Still have questions?
Please contact Lexmark Technical Support for additional assistance. When calling for service you will need to know your printer model type and serial number.
Please call from near the printer in case the technician asks you to perform a task involving the printer.
Oct 28, 2010 | Lexmark X7170 All-In-One InkJet Printer
I get this error message.. an error occurred communicating with the scanning device. Please ensure that the scanning device is connected properly and try again. Nothing seems to work,, this message...
#Click Start , select Settings , and then click Control Panel .
#Double-click System . The System Properties dialog box displays.
#Click the Hardware tab.
#Click Device Manager . The Device Manager dialog box displays.
#Click the plus sign (+ ) next to Universal Serial Bus Controllers .
#Click the USB Composite Device entry, and then click Remove .
#Disconnect the USB cable from the All-in-One, wait for few seconds, and then reconnect the cable. The New Hardware found dialog box displays.
#Click Next through all of the screens that display while the Wizard installs the USB composite device, and then click Finish .
Regards
Riztech
Oct 24, 2010 | HP Officejet 7310 All-In-One Printer
Scanning problem.
Download the manual and the driver for your version of windows for the webpage link that I  sent you.
Remember where you save the driver or place it on the desktop. go to START - (right click) MY COMPUTER -  PROPERTIES - HARDWARE - DEVICE MANAGER - PORTS - LPT1 - (Right click)PROPERTIES -  DRIVER - UPDATE DRIVER -follow prompts.
Jan 02, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error During Scanning
Please check whether any other scanner is installed or not .It might be creating the conflict.
Pls remove it.
Haoppy scaanning
Omnipresent
Oct 23, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Lexmark X7350 All-In-One Printer Logo
101 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
