Ihave a payne furnace and im installing a cased fan coil onit the fan coil is apayne also and it size is the same size as furnace i want to know if i can put the front of the fan coil at the back of furnace
  • 821 Answers
Hello,please kindly visit the link below to see a picture of the payne,and an installation guide.
www.docs.hvacpartners.com/idc/groups/.../01-8110-702-25-090808.pdf
www.docs.hvacpartners.com/idc/groups/public/.../im-pf1m-01.pdf
wish you good luck,
take care.
Posted on Jun 04, 2010
I install 2 new honeywell non programmable thermostats. The temp never reaches the setting temp. Always 5 to 8 degrees off. I can not get the furnace to heat the home over 70 degrees. Even set at 80. Any...
If the furnace is cycling on and off and not reaching temp there is a problem in the control circuit. If the thermostat is not satisfied the furnace should be running without shutting off in which case the capacity of the furnace is inadequate because of size or problems reducing the capacity. This could be caused by an increase in home size, poor air flow (dirty filter, loose fan belts, fan running slow, obstructions in the duct), dirty heat exchanger or burner, reduced gas flow, over temperature switch bad causing the burner to shut off early, or a few more technical reasons. You may do well to call a technician to troubleshoot this problem.
Feb 09, 2015 | Heating & Cooling
3 amp fuse blows when call for gas after pilot runs for 30 seconds
check the blower motor for seized of burnt out. Fuses blow because of excess current draw and in this case if the fan is not starting everything will stop. The gas will be set so that if the fan is not running the gas will not be allowed to turn on
Nov 21, 2014 | GE Carrier Bryant Payne 1/3 Hp 115v Blower...
Furnace wiring
w-brown
y-white
r-red
g-fan
gh-probly fan heat
gc-probly fan cool
or they could be for fan on and fan auto, you can these around a bit just fan control tho
Dec 08, 2013 | Bryant Electrical Supplies
Filter for Payne (Carrier?) Heater FB4CNF024??
Yes what you say is right try home depot ,canadain tire, lowes, they all do filters with differant sizes you can get them in 12 , 10 what ever you need
Feb 17, 2012 | Heating & Cooling
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
Electric furnace will not turn off
Your sequencer is stuck. A sequencer uses a small coil to warm up the switch so that it will turn the electrical elements on one at a time instead of all at once. If they all come on at once the amp draw would throw the breaker. It is also desired to have warm air come out of the vents when the fan comes on. So how do they do it? With a sequencer:
A sequencer can have up to 4 stacks depending on the amount of coils are in the heater. Each coil on average has a value of 5000 watts. So what ya want to do is turn on a coil then after 30 seconds another coil then after 30 more seconds the fan and maybe another coil depending on your furnace size.
So in your case what is wrong? The sequencer bimetal disc inside it is jammed in the on position and therefore the heater stays on until you tun the breaker off. Replace the sequencer and party on!
Here is a page on sequencers that also features rewiring of an electric furnace
Oct 28, 2011 | Heating & Cooling
I HAVE A COMPAQ PRESARIO SR1339UK, THE PLASTC
you can install an other cpu cooling.
You have to find out which socket the cpu got and the size .
it has to fits to your pc case.
Look for some videos on youtube .There are some good guidlines
for cooler installin.
A cpu cooler is not very expensive but most a time a lot better than the standart cooler.
Jun 02, 2010 | Compaq Presario Fan
I have a weatherking model number waka-037jaz just bought this with a payne furnace from a gentelman who said they worked together when he removed them but furnace doesn't have an A coil in it how do u...
The furnace can handle three tons of AC but you will need a coil and a line set to connect the two. Get a match coil for your furnace and a line set. 7/8 and 3/8 plus tstat wire and tstat. Sometimes you get stuck buying used equipment and it cost you more in the long run. I have owned a company for 44 years and I never never sell used equipment.... If you need help write back I will be glad to help you. RUSS
Jul 18, 2009 | Heating & Cooling
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
