Question about Microwave Ovens
Work normal but wont heat - Microwave Ovens
  • 2,272 Answers
Microwave is running  but will not heat up anything.
There are few possibilities which you will have to get checked
common things are
1) loose high voltage wire.
2) poor solder joint on board.
3) magnetron.
4) power relay.
If in case the time display on the microwave is counting down and the internal fan of the microwave is running properly then this NO-HEAT problem relates to bad door switch.
But in most cases its seen that bad magnetron is the reason of no heat in magnetron.
Check this link to get more details for magnetron and other parts
http://www.applianceaid.com/image/component1.JPG
For getting required parts you can get it from the online site like www.repairclinic.com
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 04, 2010
It wont heat up
If it seems to be running normally, but does not heat, then the problem is most likely in the high voltage circuit. If it smelled funny before quitting, then look at the high voltage rectifier or the high voltage transformer. Otherwise, the magnetron or high voltage capacitor could have failed.
Apr 25, 2016 | Microwave Ovens
Sharp microwave wont heat at all.
looking for a tray or plate roller wheel for a Sylvania model SM81001 ser. no. 0008001033
Nov 24, 2013 | Sharp R-1870 Convection/Microwave Oven
Not heating efficiently; works but doesn;t heat as well
If it is taking longer to heat things than normal then it would appear the Magnetron to starting to wear out, this is a normal sign of inefficient power from the magnetron & would need to be replaced.
Dec 26, 2012 | KitchenAid Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
JVM1640WB007 MICROWAVE RUNS BUT DOESN'T HEAT. WHAT COULD BE THE PROBLEM?
It is most common for the magnetron in GE microwaves to go out. This is the part that heats the food. Basically everything on the unit works and runs like normal but it wont heat. Check your owners manual for the warranty on the magnetron. They usually put a 5-7 year warranty on the part itself. If you dont have the owners manual check for it online. Hope this helps you.
Jan 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
FAN!!!
Oh, it turns out the the microwave was over heated and the fan was cooling it. The fan will automatically turn on and stay on until your microwave reaches normal temp. just unplug your microwave and let it cool off. then plug it in and everything should be just fine.
May 25, 2008 | Frigidaire GLMB209D Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
