Question about Sony Cyber-shot DSC-W170 Digital Camera
My camera does not allow me to change the flash s settings.
  • 87 Answers
Check if you are not in Burst mode as flash is disactivated in it.
Posted on Jun 04, 2010
Picturess are too green
there are advanced color correction modes,
Blue or dark pictures/videos
Keep your shooting distance inside of 2ft to 3ft, depending on
visibility and ambient light.
If you are using only one light, considering adding another light
(dual lights) or/and external flash accessory. The ideal
set-up is a combination of a light plus flash.
Consider purchasing the SeaLife Wide Angle Lens (SL975). The
fisheye lens allows you to get closer to the subject and fit more
into to picture frame.
For SeaLife camera with external light accessory (No external flash):
1) Set the camera's scene mode to Sea mode or Snorkel mode
2) Change camera's PHOTO and VIDEO White Balance
settings to DAYLIGHT.
For SeaLife camera with external light and flash accessories:
1) Set the scene mode to Ext. Flash mode
2) Change the VIDEO White Balance setting to DAYLIGHT.
For other underwater camera brands:
1) Set the Scene mode to "Auto" or "Underwater" scene
mode, as recommended by the camera manufacturer.
2) You may also need to change the White Balance setting to
DAYLIGHT depending on the camera's underwater color
correction or if pictures/video turns out red.
Mar 05, 2014 | SeaLife DC1200 Digital Camera
My 580ex ii cannot change back to Auto zoom its stuck at 14mm
If removing the batteries overnight doesn't allow it to reset, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Nov 01, 2012 | Canon Cameras
How do I turn the flash on
Since you didn't provide brand and model info - only generic help can be given.
Most cameras will automatically turn the flash on when conditions are too dark for a successful exposure. Many times, the camera will not allow you to take the picture if the flash can't be turned on. You'll have to go through the menu settings of the camera to find a Flash Setting. Popular choices are often Always Flash, Never Flash, Red Eye Reduction and Automatic Flash. It sounds as if the setting was changed to Never Flash - or the flash bulb itself has failed.
If you have problems still - provide the manufacturer and model camera you're using and I'll see if I can find out how to do it for you. Good luck!
Oct 08, 2010 | Cameras
Screen says 'can not change flash settings'
if you need a manual go here
http://www.retrevo.com/search?q=Sony+DSC-H9&rt=oa&modelid=1075104
on page 50 is has a chart showing when the flash is used, or not available. P S A M all make it available, in Scene, or the one with the mini camera, it is not adjustable. If it will not work in PSA or M then it will need to have a tech look at it, Please try changing modes first and let us know if this was your problem.
Apr 30, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
N auto mode of shooting flash setting cant be changed in sony cyber shot model no dsc w-170
as long as you have a menu button on your camera you should be able to control these functions.turn the camera on in auto or manual. hit menu soon as the camera comes on,now you should be allowed to make any chages you choose.hope this helped.good luck
Apr 14, 2009 | Cameras
My DSC-T100 won't allow any changes to the flash setting.
The flash settings on the Sony Cyber-shot DSC-T100 are Auto, Forced Flash, Slow Syncro and No Flash, if it is not giving you a flash and wont allow you to change the setting you might have to talk to sony or the store you bought the camera from. One long shot would be that depending on what other features you are using on the camera, i could be set up to not allow you to change the flash settings in that "mode". Sorry if this is useless, but good luck and if all else fails use sony support! :)
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7
stupid hyperlink not working :(
Nov 21, 2008 | Sony Cyber-shot DSC-T100 Digital Camera
Flash problems
As you haven't said which shooting mode the problem occurs under (e.g. Auto, Scene etc) I can only suggest that you try different shooting modes to gain access to changing the Flash settings. Hope this helps.
Apr 29, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Flash
I assume you have a digimax D53 as this is where your question is posted. On the top of the camera is two black buttons and the silver button which is the shutter release. One of the black buttons, the one closest to the silver button, is marked with an "M". This button can be pressed while the camera is on and it will allow you to change the settings for flash and for exposure. Suggest that you change it to auto as this is all around the best setting for snapshot type photographs.
Mar 22, 2008 | Samsung Digimax D53 Digital Camera
Flash for Coolpix L6 Digital
You can try to reset all of the internal settings. This has worked for me with a digital camera.
It would be good here to know what kind of camera we are working with.
Make sure you do not have any of the settings in the camera set to turn off the flash...for instance setting it at mountains or most any outside setting may not allow the flash to work. Some cameras will allow you to override the setting internally.
If the flash does not work at all, then repairs will be needed.
Dec 18, 2007 | Nikon COOLPIX L3 Digital Camera
Sony Cyber-shot DSC-W170 Digital Camera Logo
66 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
