What is error 5700 for canon mp780 printer - Office Equipment & Supplies
    President:
  • 1,561 Answers
Error 5700 means the paper sensor is not working on your printer.
Take care.
Posted on Jun 04, 2010
  • tao_wang1715 Jun 04, 2010
    Thank you. What should I do next?
  • Sulaimon Jimoh Olayemi Jun 04, 2010
    5700 is a ASF cam error most likely. Here the Canon proceedure for
    fixing it!
    DESCRIPTION: 5 Alternating Blinks (SFP) / ##356 (MFP) -
    ASF Cam Sensor Error
    SOLUTION(S): Adjust the Screws & Main Case
    Unit
    Movement (i.e. from shipping) may cause the plastic guide to
    move away from the chassis. When this
    occurs, the gears cannot rotate
    properly causing a grinding noise and 5 alternating blinks (SFP) or
    ##356
    (MFP) - ASF Cam Sensor Error.
    Procedures
    Step 1: Remove
    the Left and Right Covers and the Main Case Unit (main cover).
    Step
    2: Remove the 4 mounting screws from the Chassis.
    Step 3: Remove the
    Main Unit from the Bottom Case.
    Step 4: Turn the Main Unit over
    (upside down) and place on work surface.
    Step 5: Inspect the ASF
    section of the Main Unit for a gap between the white plastic guide and
    the Chassis.
    Note: The size of the gap varies. Even if the gap is
    not visible, complete the steps
    below.
    Step 6: Disconnect the
    appropriate cables and remove the Logic Board from the Chassis.
    Step
    7: Loosen (do not remove) the 4 mounting screws (the mounting screws can
    be found behind the
    logic board) on the Chassis.
    Step 8: Re-seat
    the white plastic guide so it sits flush against the Chassis. The tip of
    the white plastic
    guide should sit slightly inside the
    mounting
    screw hole. When seated correctly, the gap will no longer be present.
    Step
    9: Tighten the 4 mounting screws without
    causing the plastic guide
    to shift.
    Step 10: Reassemble the printer and retest.
    Take care.
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Feb 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a canon mp780. Shows an error code of wrong cartridge, even though I have replaced all the cartridges with new canon ones.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444#SupportDetailAct
Click support tab. Type "error wrong cartridge" - follow directions in results
Nov 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780
You get that message when the printhead goes bad. It's not the ink cartridges. You need a new printhead
# QY6-0049-000 around $60.00
Nov 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Jun 08, 2009 | Canon MP520 All-In-One InkJet Photo...
It never works cuz the screen says error 5700 and wont do anything
Error 5700 is usually a paper "feed" jam.Check the automatic paper feed area to see if any paper is jammed
May 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Makes a loud popping noise and won't print
http://damnprinter.com/226/canon-service-call-errors.html this site will tell you a couple things you need to know it says a sensor error
Nov 10, 2008 | Office Equipment & Supplies
PRINTER FAULT
I,m not 100% sure on this. But A 5700 error on canon printers.
Would mean that the paper sensor has failed, or is not working.
Hope this Helps.
Regards Mike@Compurepair.
Feb 20, 2008 | Office Equipment & Supplies
CANON IMAGECLASS M7 5700 SERIES
first thing is to go to www.canon.com and find your local support links, and download the fresh set of printer management software or drivers.
got backup for your computer?
Feb 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Unable to Print
Maybe if you rubbed some cheese on the front, that would work? Hope this helps.
Apr 24, 2007 | Canon PIXMA MP780 All-In-One InkJet...
jasbo
jasbo
