Question about Haier Refrigerators
My refrigerator (HTV15WNCWW) freezes fine but the refrigerator freezes everything also. I made about 2-3 inches of space in front of the freezer vents, still same problem. When the freezer is pumping air out the frig is too.
Bob Gemmell
  • 209 Answers
SOURCE: Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
Posted on Sep 28, 2007
watugot
  • 290 Answers
SOURCE: White Kenmore 564.98291890 - Freezing in refrigerator
This is a pretty simple built refrigerator, no circuit boards or electronic sensors.
What it sounds like is your thermostat is sticking and not turning the compressor off when it gets to the correct temp.
The control knob is mounted directly to the thermostat, so when you turn the knob you are turning the thermostat.
The only thing you can do is replace it. It is a pretty simple repair you should be able to do yourself. Once you have the new part, UNPLUG the fridge, remove the knob and take the control box loose. You should see how to change it from there.
Be careful with the long metal tube that is attached to the new thermostat. It is pretty durable but if you break it the thermostat is ruined. They don't break easily but you should be sure not to kink it..
Post back if you need help with it.
Posted on Oct 25, 2007
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
SOURCE: food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Posted on Jun 24, 2009
woodchuck789
  • 4059 Answers
SOURCE: Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 01, 2009
The refrigerator is freezing the food
thermostat defective,should be change by expert
Jun 28, 2014 | Amana ARB8057C Bottom Freezer Refrigerator
Freezing cooked turkey
I just put the equivalent of 2 six kilo turkeys in single portion containers in my freezer plus 7 single portions of homemade gravy. You can freeze it and use it no problem even a year or two later. On the net if you research freezers they recommend that it must be 0 Fahrenheit (or -17.77 C) and everything must be used before 3 months to avoid freezer burn... but do you believe everything you read on the internet? :) One or two years is fine
Nov 28, 2013 | Refrigerators
The freezer door will not close tight
Hello, check the freezer sliding door rail. Removed everything in your freeze then gently slide out the freezer door. Check the bottom of the freezer for food items that may have dripped into the bottom of the freezer. Now, the check the roller rails along each side of the freezer there could have been widget that got smash by the roller on the freezer door, if you find this smashed widget--he not drunk--he is dead. Scrape the those roller rails and clean the and get all the globs,ice cream, widgets, pieces of other different types of freezer flub.
Next, set a level on the freezer door and see if the bubble is point forward, if not then screw up the front two leveler in the front of the freeze--one on each side in the front of the freezer/refrigerator. I hope this help you. GB...stewbsion
Oct 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer will not get cold
Hi..
You need to check this following:
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
Good luck !!!
Regards
PCmania
Jul 10, 2009 | GE GSS25LGM Side by Side Refrigerator
NOT LEVEL
Lower the front. But the back needs to be slightly lower that the front in order for the door to swing shut atomatically. While your working under the front, check the condenser coil (wire racks, usually 2-3 layers with a 1/2 inch space between them). Use a vaccum cleaner and **** out any dust. This will make the refrig run less and cool better.
Sep 15, 2008 | Hotpoint HTS18 Top Freezer Refrigerator
Freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Sep 14, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
My fridge stays on and freezes everything inside
not a breathing room issue, if anything that would cause it to shut down and not cool at all, where you got just the opposite, it never shuts off. is it an electronic model, or is there a control knob you manullay turn to adjust temp
Feb 23, 2008 | Sanyo SR-4910M Compact Refrigerator
Refrigerators Logo
76 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
