Question about LG 24 in. LDS 5811 Built-in Dishwasher
Water not draining - LG 24 in. LDS 5811 Built-in Dishwasher
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasherwater not draining - 2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 04, 2010
How do I drain the water tank
Anon, Make sure gas or breaker(power) is turned off to the Heater so it will not come on during draining,connect a hose onto bottom valve of water heater, run hose to a floor drain and insert, turn your water main off so as not to fill tank while draining, open water heater drain valve, water will then drain from attached hose into floor drain until empty. For water to run faster you may open a near by hot water tap, this will allow air into tank as you drain it, do not forget to turn this tap off before refilling tank. You then can turn main back on for a bit if you would like to do a flush of sediment from the bottom of tank.
See links below for more instruction and video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Drain Water Heater Today Homeowner
How to drain water heater
http://www.bobvila.com/articles/how-to-drain-a-water-heater/#.VxqJ6NQrJxA
Apr 22, 2016 | Water Water Heaters
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
I just noticed that my hot water heater that is 6 years old is dripping very slowly from the bottom faucet, how can i stop this leak. thank you.
If you mean the drain valve, then buy garden hose cap at home center.
Cap will have rubber washer that seals tank.
If drain valve is plastic, the cap may not thread on without sanding down end of plastic drain valve.
Otherwise replace drain valve, which is simple if drain valve is brass, but can be difficult if drain valve is plastic.
Turn off power to water heater: Electric: turn off circuit breaker. Gas: turn knob to pilot.
Turn off water, open bathtub spigot on Hot side, drain water heater, remove drain valve with wrench.
If plastic drain valve breaks while being removed, then 'gently' break out broken part using hammer and big screwdriver.
Buy new drain valve at box store in water heater department.
Put teflon tape on new drain valve threads.
http://waterheatertimer.org/Water-heater-is-leaking.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Not washing dishes
check the water make sure the water is correct. fill water drain water and circulation water.
fill water comes from under sink, drain water from drain pump and drain hose ,circulation pump controls the water washing. let me know if this helps.
Mar 06, 2010 | Dishwashers
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Oct 01, 2009 | 2006 Chevrolet Monte Carlo
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
1,329 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
