Question about Pioneer CT-W208R Single Cassette Deck
The balance of the rec level is not good how to solve the problem on the ct-w208r cassettedeck player? this unit is brand new out of the box.
  • mivanzeeland Jun 07, 2010
    This make no difference , i also checked the kable's and replaced them , I also used other tapes.
    When you record both peak-meters give the same peak-levels.
    when you play the tape the peak meter of the right channel is lower then the left channel.
    what can this be?
    Champion:
  • 222 Answers
Clean the Tape and erase head (these are the small block stainless and white plastic which the tape passes) with cotton ball slighty damped with rubbing alcohol
Posted on Jun 06, 2010
  • Doldog Jun 08, 2010
    Then you need to replace the tape head, it is already worn-out
  • Doldog Jun 09, 2010
    try calibrating the head, there is a small hole on the front face of your tape deck just below the tape cover, you need a small phillips screw, play a good tape on while playing turning the screw driver slowly clockwise until it is fully thigten then slowly turn it counter clockwise you'll hear the difference in the sound while doing this, stop turning the screw when you hear the best sound you can attain
Please compare pioneer ct-w208r and ct-w604rs
You are on the wrong website for this type of inquiry. This is a self help website for the repair and use of consumer manufactured products
Jun 20, 2017 | Pioneer Computers & Internet
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
Marantz pmd520
The PMD520 doesn't have balanced XLR inputs; only unbalanced phono/RCAs. If your source has phono outs too, then use those, because the benefit of balances inputs is lost when converted to phono.
If you still want to go ahead, then buy some balanced to unbalanced converters.
Studiospares RED502 Bi Directional Balanced Unbalanced Converter
If you try to do this on the cheap by wiring an XLR to phono, be aware that the studio level output of balanced level connections is about 2V rms. The live input level for unbalanced is around 1V rms. You'll either need to pad the input to reduce the level or run the cassette REC level controls nearer to the bottom of their adjustment range where they're a bit noisier and not so linear.
Apr 28, 2014 | Audio Players & Recorders
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Pioneer audio video multichannel rec vsx-d810s the remote for this unit xxd3028 will not balance the speakers anymore. The batteris are new. What next
Have you tried balancing it from the Receiver?
What happens sometimes is that when the battery dies and you still use it,the buttons on the remote don't work.
The possible reason can be Dust,age of the unit can be another factor.
Pull remote's faceplate off and check the contacts, make sure there is not something obstructing or not allowing your faceplate to make proper contact.. You might need to pullout the screws using a screw driver.
The last option would be to buy a new remote.
Good Luck.
Mar 29, 2010 | Audio Players & Recorders
My Magnavox MWR20V6
If unit is still under warranty return it. If unit is still sold at the orginal place of purchase buy another and return the first one stating it wont work and get a refund
1) power source is good? (receptical on the wall or power unit. Locate DVD rec. to another receptical and check Rec. again)
2) power cord going to unit is good, no cuts or melted spots
3) power setting on unit is correct (small red slide type buttong for different country voltage settings)
4) internal fuse, change it even if it doesn't look bad.
5) Weigh the cost of a new one to the repair cost of the old one. If you buy a new one get a good brand RCA is still one of best and longest lasting.
Jul 18, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Black pic on tv fm dvd rec
Several possibilities. If there is a HD box going into this unit, it will give you this message. If there is a modulator or converter box between the cable/sat box and this unit, it will give you that msg. If you have an input plugged into an input, it will give you this msg. Finally, if you have anything other than a camcorder plugged into the FRONT of this unit, it will give you this message. Recheck your connections.
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
JNC MP4 Player Model MP177703 1GB
I’m going to give this to you in Hong Kong English J
http://www.jnc-digital.com/jnchk/eng/sns/faq/ - JNC website will answer all questions
Most of customer who case this matter, when they are still download or upload the data, which once case the system hang. Most of customer, accord to the following steps to format their mp3 player once, which can help them to solve this matter.
  • 1.Install the battery, Press and hold the “MENU” and “REC” button at same time to turn on your mp3 player.
  • 2.Then you can see “MP3 PLAYER MATE V1.000” on the screen. But please remember don’t release the “MENU” and “REC” button.
  • 3.Until the player enters to the MP3 mode. Then you can release the “MENU” and “REC” button.
  • 4.Complete.
If there is no any improvement, please repeat step 1 to 3
-Tha Mp3 Doctor
May 16, 2008 | JNC Computers SSF-310 MP3 Player
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
Pioneer CT-W208R Single Cassette Deck Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
