Question about Toshiba DVR610 DVD Recorder/VCR
Blue screen on tv - remote control programming issue?
DVD/VCR worked fine last night. Woke up this morning and had a BLUE SCREEN on the tv. The VCR works fine on playback on Video 2, however I now can't record at all. TV picture from tuner doesn't show on Video 2, only video playback. Also, the SET UP commands won't show up on the screen. I believe a remote control got a button accidentally pushed and something programmed wrong, but can't figure it out. Did the whole customer support call with Toshiba - no help at all. I believe it's a setting issue attached to the remote, but can't figure it out. All connections are secure and correct.
  • 82 Answers
SOURCE: After I record a TV program there is no video put there is audio
get a coax to video converter with video in and out on it it will tell you how to hook it up which is common since you can get them at walmart and kmart run the coax of reciever into the ant in part run coax out to tv run rcas out to dvd player
Posted on Feb 06, 2008
SOURCE: toshiba 35a44
I contacted Toshiba and they said to turn unplug the TV for at least a minute, if that didn't reset it, then they gave me a service to contact. So I unplugged the TV when I was going to be gone all day, and tried it when I got home, no change at all. I had a repairman come by and he said the problem were the buttons on the TV that had to be replaced. He quoted me $240/labor and $5 for each button to replace (7), considering I only paid about $500 for the TV in December of 2004, I decided to just get a new tv with a warranty. I ended up getting the LG LCD Tv.
Posted on Aug 02, 2008
SOURCE: programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Posted on Sep 12, 2008
SOURCE: Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
Posted on May 12, 2009
  • 1213 Answers
SOURCE: My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Posted on Sep 25, 2009
Vcr emerson ev477 programming
vcr ? what is a VCR are u kidding ? no really blue ray smart DVD 3D 4K bluetooth wi fi wireless ethernet on line all share miracast screen miroring tablet touch screen
Aug 22, 2014 | Emerson EV477 Video Cassette Recorder...
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Mitsubishi hd 1080
What about the cable input? Does it work?
Sep 05, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Tv is stuck on blue screen
i would suggest cycling thru the inputs- av1 av2 rgb hdmi. blue screen is indicator of no input.
Apr 07, 2009 | Televison & Video
Problem with old TV
The channel is almost always 3 or 4. Be sure you have the VCR connections correct. Just hook up the TV and VCR alone to start with and try both the VCR and DVD. Also the output of the VCR should show a blue screen.
Dec 17, 2008 | Memorex MT1194 19" TV
There is a lock on my screen and nothing works
Try holding the display button for 10 seconds, worked for mine, unless the vcr presents a different issue
Nov 10, 2008 | Insignia IS 20" TV040919 TV
Nothig bu a blue screen shows when turned on
Blue screen of Death?
No, this is not windoze.
can you change channels?
a blue screen usually means that you don't have a signal.
Is it hooked up through dvd/vcr player?
Try a straight connection to cable or antenna.
If it remains, then it requires surgery.
Sep 30, 2008 | LG 42LC2D 42 in. LCD HDTV
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
Mom was hitting buttons and now DVD plays Blue and White!
I think your mom changed the DVD output setting. Using the remote, go to the Setup Menu, then select DVD Setup. Scroll down to the Alt Video Out option. It will either be set to "Component", S-Video, or "Off". It needs to be set to the type output you are using to go from your Go Video deck to your TV. If you are using an S-Video cable, then set it to "S-Video", if using Component cables (Red, Blue, and Green cables), then set to "Component". Otherwise it should be set to "Off".
Hope this helps.
Nov 26, 2006 | GoVideo DVR4000 DVD Player/VCR
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Toshiba DVR610 DVD Recorder/VCR Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
