Question about Car Audio & Video
Have a 2003 Acura TL 3.2 sedan, need to reset stereo code as the code documented in the book does not work. Need instructions too. Thank you
  • 4,885 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
Posted on Jun 05, 2010
How to change headlight bulb in 2003 Acura 3.2 CL
Nick, To see how headlight bulb is changed, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Replacement How to replace install fix change hid head light ballast...
Headlight Change 1999 2003 Acura TL 1999 Acura TL 3 2L V6
Acura TL Headlight Replacement WITHOUT removing the bumper
Aug 06, 2016 | 2003 Acura 3.2CL
ACURA TL 2003 radio CODE
if you have the owners manual that came with the vehicle the code should be in that or on a card that comes with it, if you don't have the four digit code a good auto audio dealer should be able to source the code for you, I'm in the UK and thats how it works here, hope it's the same for you
Regards
Jim
May 29, 2010 | 2003 Acura 3.2TL
I have the radio code for my acura tl 03 but it still doesnt work what shoul;d i do
Call dealership where the car was purchased make sure you tell them you are the original owner and have them help you through it or if you have the book it tells you- other instructions: If you have jumped or replaced the battery at anytime this will happen. You have to get the serial number off the radio by removing it or partially taking it out to see the numbers on it try not to remove any cords. With the stereo out (to make sure you get the right number off of it) call an Acura dealership with the number and they will give you the another number to enter into the stereo and directions on how to punch the numbers in. Make sure while you have the stereo out you write the serial number down and keep it in a safe place also the number that the Acura dealership gives you because if you sell the car or if it happens again its easily accessible. Good Luck!
Apr 22, 2010 | 2004 Acura TL
I disconnected my battery and anti-theft code came up on my radio . i have 2003 acura tl s type. radio sereal # BA002234 stereo u3000 L2234. i need a code to unlock it
all you have to do is go to dealer with that serial # and they will give you yhe code, bring cars registration and id to prove its your car, i do it alot but over the phone because dealers know me,hope this helps.
Dec 13, 2009 | 2004 Acura TL
2001 acura TL stereo unlock code
I have a 2001 Acura TL that I bought a month ago and the stereo volume wont go up past 1. Do i need to replace it or unlock it?
Sep 18, 2009 | 2001 Acura 3.2TL
How to reset the maintenance code B12 on a 2007 Acura TL? Just changing the oil doesn't clear the code.
hold the reset button for 30 secs then will enter a new screen press the rest one more time than done
Jun 11, 2009 | 2007 Acura TL Sedan New Cars
Security code for my 1999 acura TL stereo system
look on the fusebox, glove compartment for a number
Feb 04, 2009 | 1999 Acura TL
Acura 3.2 TL 1999
call the dealer with the radio serial # and they can give you the code.
Dec 27, 2008 | 1999 Acura TL
Radio code
hi..i need to find the code for my 2004 acura tsx stereo .my battery died and when i turned it on it says code
i pushed the 1 and 6 at the same time and it gave me this #s u 1002 and L 0718 can u please help me
my email adress is nvrrntn@yahoo.com
thanks in advance
Aug 03, 2008 | 2004 Acura TL
Car Audio & Video Logo
190 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
